Look guys. The L3-Multimaximizer made me happy. If a manely slam and or weiss eq can do much better in terms of overall pleasing mix and >+5.00 rms average on a K scale (-9db rms on linear) without graininess and loss of stereo image, then I'll spend the money. I'm an engineer/producer, former professional picker, and entertainment attorney with 25 years of experience, and can buy just about anything I want to get a better product, but the L3 sounds pretty damned good already. BTW I use the L3-Multimaximzer first in line with the IDR set to 24bits, type 1, normal, then the L3-Ultramaximier after and dither it to 16bit, type 2, ultra, to get that level. You all know, and don't kid yourselves, the loundness war will never go away until playback manufacturers implement automatic volume adjustment. Its up to you to figure out how to make a master loud, clean and articulate, and dwell upon how to avoid it. I think if I were working in a 96 or 196 environment on a TDM system (on which I use to work..48 channel procontrol with digi converters and preamps), with the L3, my masters would sound even better,but i'm mixing and mastering on an LE system at 24/44 clocked to an Apogee Big Ben and I'm willing to accept the difference in quality because the price threshold is so high.
I just can't imagine outboard gear would make that much difference given the same mix. In fact, I've seen numerous complaints about the capabilities of the manely products to deliver loudness without artifacts. I think the real difference between quality commerical masters is the skill of the recording engineer and mixer, the mix format bit depth, the D/A and A/D converters and/or clock source, in that order.
Now, go ahead and kick my ass for saying so.
