Pages: 1 ... 6 7 [8]   Go Down
Author Topic: Show us your room! pics 2007  (Read 30460 times)
Andrew Hamilton
Re: Show us your room! pics 2007
« Reply #105 on: March 08, 2007, 03:27:28 am »
tom eaton wrote on Wed, 07 March 2007 00:14
Dude, eyeryone knows the thick cables go from the amp to the speakers and the thin ones go from your gear to the amp.  Your setup must sound terrible.  No hospital grade outlet for your amp, either.  Lame.
Oh...sorry.  Had to say something negative to make myself feel better.  Still waiting for a big enough room to get my own Dunlavys.
How far back into the room is your listening position... and how much distance between you and the back wall?
-tom
Hi Tom,
    The speaker cables are from Home Depot.  They are stranded 6 gauge and the mic cable interconnects are bundled in a black plastic hose.  So the speaker cables _are_ thicker than the gear cables!   The amp has large military-style capacitors and is balanced throughout.  Yes, the SC-Vs are far field monitors.  I sit about 12 feet from the tweeters.   My head is a few feet from the back wall, which has a huge bass trap behind me, containing about 5 feet of Roxul
www.serifsound.com
premastering for CD and DVD-A.  Featuring FTP load in and delivery as well as analog tape transfers.
Andrew Hamilton
« Reply #106 on: March 08, 2007, 03:38:16 am »
punisher wrote on Wed, 07 March 2007 19:30
What I'd like to know is how much are selling that $hit per lb?
ha.  Would that I could harvest the walls.
As for the controversial carpet choice, the room is only rented, so I'm not going to change the aesthetics dramatically.  Also, I'd like to keep it vintage for historical reasons.  The room was built by Queen City Album (Cincinnati) for tracking in 1977.  That carpet is 30 years old!  I was 10!  When and if I vacate, I will restore its functionality as a (vintage) tracking room.  My few acoustical modifications would be beneficial for that and are invisible.
Interestingly, no one has asked about the little video camera mounted on top of the left speaker.  That's an in-house surveillance camera feeding the control room (behind me).  If I want to track a drum set and not have it in the iso room (also fitted with a cam), I can set it up in the mastering room.  Before I built the bass trap behind the listening position, it was a large studio glass between the tracking and control rooms.  That control room is still used for mixing-hat days and makes a handy machine room for the computers on mastering-hat days.  The computer and digi cables go through the patch panel on the back wall of the mastering room into the control room.
Andrew
www.serifsound.com
bblackwood
« Reply #107 on: March 08, 2007, 07:33:00 am »
Andrew Hamilton wrote on Thu, 08 March 2007 02:27
You sure about that? I'm pretty sure none of Nelson's design are fully-differential...
Brad Blackwood
euphonic masters
compasspnt
« Reply #108 on: March 08, 2007, 09:39:57 am »
Congratulations on converting the tracking room...probably a good, and good sounding, idea.
But shouldn't you also place a tiny camera on the right monitor, to "keep them in balance?"
Jerry Tubb
« Reply #109 on: March 10, 2007, 01:18:30 am »
My Room in 2002...
index.php/fa/4490/0/
It looks & sounds much different now : - )
JT
Terra Nova Mastering
Matt_G
« Reply #110 on: March 10, 2007, 05:40:11 am »
You'd better watermark that photo Jerry or someone might steal it  Laughing
Matthew Gray Mastering
Brisbane Australia
Gold
« Reply #111 on: March 10, 2007, 07:23:57 am »
The first time I heard  an A7/mac combination was at the 2003 AES NY convention. I was shocked at how good it sounded. If I didn't live in close quarters in NYC there's no doubt it would be my home listening setup.  It was really fun to listen to.
Paul Gold
www.saltmastering.com
On the silk road, looking for uranium.
compasspnt
« Reply #112 on: March 10, 2007, 01:16:42 pm »
Yeah, anyone with the A7/Mac combo: put on a vinyl copy of "River Deep, Mountain High," turn it up, and be totally amazed.
Jerry Tubb
« Reply #113 on: March 10, 2007, 03:57:56 pm »
OK guys, since your gettin' off on it... here's a close-up:
index.php/fa/4494/0/
A cherry Mac 275, original tubes iirc.
We were using the rig to shoot tones & noise in the room, listening for modes.
and of course some enjoyable nostalgic listening.
Thought of upgrading the drivers and rebuilding the crossovers...
The room was a great reverb chamber at the time.
JT
Andrew Hamilton
« Reply #114 on: March 13, 2007, 11:38:44 pm »
bblackwood wrote on Thu, 08 March 2007 07:33
Hi Brad,
    This is one of his SuperSymmetry amps.
From the manual:
"The supersymmetric amplifier is a special subset of balanced amplifiers...  Supersymmetry is an approach that truly takes advantage of balanced operation like no other and requires a balanced input to retain the precisely matched behavior. Supersymmetry is ideally used to obtain high quality performance from very simple circuit topologies...   The supersymmetry topology does not use operational amplifiers as building blocks, nor can it be represented with operational amplifiers.  It has two negative inputs and two positive outputs and consists of two matched gain blocks coupled at one central point where the voltage is ideally zero.  The topology is unique in that at this point, the distortion contributed by each half appears out of phase with the signal, and we use this to reinforce the desired signal and cancel noise and distortion.  This occurs mutually between the two halves of the circuit, and the result is signal symmetry with respect to both the voltage and current axis, and antisymmetry for distortion and noise.  This means that the distortion and noise of each half appears identically and cancels."
_andrew
www.serifsound.com
Andrew Hamilton
« Reply #115 on: March 13, 2007, 11:43:11 pm »
compasspnt wrote on Thu, 08 March 2007 09:39
Actually, the right speaker stays level with the left, even though there's no camera on top of the right speaker.  ();  Fortunately it's so small as to be acoustically transparent - even more so than the Dunlavy grill cloth, which I leave off, for visual impact.  (:
_andrew
www.serifsound.com
Pages: 1 ... 6 7 [8]   Go Up
