Not all OPAMPS are little 8-pin chips.
discrete opamps understandably will sound better, and can be made to work...
they are not the BEST but they are easy to implement..
OPAMPS are not the guilty culprit... engineers and manufacturers are.
virtually every 80's piece of audio gear made use of the tl072 or 5532 chips and their close relatives..
manufacturers finally had ONE or TWO components which could replace the MAJORITY of components in a piece of audio gear..
every mixer from soundcraft, allen&heath, auditronics broadcast, eq's, compressors.. you name it.. they all implemented said opamps NOTICEABLY reducing production costs..
buying the same component in very large numbers, and not having to select (opamps do not need selection like discrete transistors) made things CHEAPER..
using opamps also meant using younger cheaper engineers..
it also meant NOT being forced to use TRANSFORMERS, CLEAN POWER SUPPLIES, INDUCTORS (gyrator circuits or parametrics) etc..
every audio function as well as anything else was done with the wonderful, cheap, do-it-all OPAMPS...
So I don't think all opamps are the same... but THOSE opamps are no good..
as far as audio, asymmetric class A discrete still beats most everything else.
