Socrates wrote on Tue, 23 January 2007 21:58 |
John Monforte wrote on Tue, 23 January 2007 19:57 | ...Power supplies in gear have regulators in them that isolate gear from dippy, spiky and fuzzy utility power...
I used to take this position quite strongly myself, but I was exposed to some situations where the noize was getting through. My thought was that the high frequency interference does not play by the rules and leaps adjacent wires that have tiny capacitive coupling and so on.
Regulators have to 'respond' to a change, and they have a reaction characteristic which is usually pretty slewed. For that reason they do tend to let HF noise through.
And Toroidal power transformers frequently have strong capacitive coupling between the primary and secondary, because the two are wound right on top of one another.
Put these two together, and you can DEFINATELY see how HF noise can and often does find a way through onto power rails. Now, consider the number of high-frequency switching power units out there, and it becomes plausible that there could be HF noise to find it's way through onto your DC power lines.
So maybe I appear to have argued against myself there, I'm not sure... -All switching power supplies seem to have L/C filters on their AC power input connections though, to prevent this sort of muck from getting out.
RF noise on the lines coming into boxes can be treated though. What John M. says is an excellent approach, in my view.
However, I certinly have had people proselytize to me about how their new power conditioner "got rid of the 60Hz noise"...
-That's really a neat trick! -Without that "noise", most conventional power supplies will cease to function!
The 'Hospital power sockets' (hey, I know it's very pedantic of me, but can we PLEASE stop calling them "plugs"? -They really AREN'T plugs, they're
SOCKETS, ferchrissake!!!
) won't do a thing for you if you just swap them out and don't change the ground wiring... you HAVE to add a single, insulated ground return to the central point at the fusebox.
In the UK -interestingly- this approach is VERY uncommon. The British power wiring regulations require what's called a "ring main", where power is wired through three 'loops' around a room: a live ring', a neutral 'ring' and a ground 'ring'. The idea is that if you use 20Amp wire, every socket on that ring will have 2 x 20 amp paths in parallel. This distributes the load and reduces current-driven dips. -Certainly, just about every house in the USA that I've ever been in, the lights dim when you turn on a hair-drier. I don't recall ever noticing the effect in any UK home which was wired in the last 30 years or so...
So we have more constant power in the UK. -Yay! -But I can also tell you that 50-Hertz induced hum just doesn't respond the same way to the same rack wiring approaches. If two things are grounded to different sockets in the UK, the loop areas in play suddenly get very large, and the induced ground currents tend to modulate the ground potential, or cause a tiny current to flow up and/or down the ground conductor in your power cable... YIKES!
So yet again I have realised that I should -in the interests of more comprehensive posts- have prefaced my posts earlier with "In the USA..." -But I hope you get the picture.
Here's a simple thought we can hopefully all nod our heads to:
If power grounds all star back to a nice, quiet (unmodulated) ground point, and care is taken so that loops are not set up which can induce current to flow along the cables, (I mean... they're running RIGHT alongside some 50Hz/60Hz cable with
BIG AC voltages on them, and sometimes a sizeable current flowing also!) then power ground should be quiet.
Quiet power ground can certainly work as well as a good technical ground, but sometimes you can't get power ground very quiet (because you're next door to a metal-lamp-post fabrication facility with a hundred arc-welders going all hours, dumping massive currents into power ground, and modulating yours no matter WHAT you do!) then a technical ground may become VERY important in your future.
See... This is why Art Kelm over at "Ground One" gets a lot of work. The solution varies with the problem, the problem varies with the location. There's not a simple rule, there's several rules, there's experience, there's testing and there's VERY often a combined-approach solution to most problems.
-Put it all together and you've got a consultancy.
-That'll be twenty-five dollars, please.
-I'll take payment in GB
