Dave Scoven wrote on Wed, 07 February 2007 14:09 |
Bruno, I can see that recording at 44.1 then bumping it all up to 88.2 does nothing but waste space. I can also see that 88.2 processing of a signal recorded at 44.1 doesn't do anything to improve the fidelity of the 44.1 signal.
But I wonder if mixing at 88.2 does give the effects a better sound. Not that the original signals sound better, but the verb introduced during mixing sounds better at 88.2 than it would if you mixed at 44.1? Does that make sense? Of course then you loose it again when you go back to 44.1, so the thrill is short-lived ... Unless something is preserved when you go back to 44.1...
I asked a similar question in the WW forum, and the concesus has been that mixing into a higher sample rate is useless if ITB, but usefull when mixing on a console, then back into the PC for 2 track. Here's how I see the possibilites, and the conclusions ... please let me know if I have it right (assume all ITB):
1. track at 44.1/24 - mixdown to 44.1/24 --> mastering (back to 44.1/16)
2. track at 44.1/24 - mixdown into 88.2/24 --> mastering (which brings it back to 44.1/16
- It would seem that this does nothing over 1, since the upsampling to 88.2 is point less
3. track at 44.1/24 - upsample to 88.2/24 - mixdown into 88.2/24 --> mastering (which brings it back to 44.1/16
- This is what you're asking about above. It seems that you gain the higher resolution for plug-ins during mixdown
- Resource intensive (ie space, CPU power, etc.)
- sounds best while mixing
4. track at 88.2/24 - mixdown into 88.2/24 --> mastering (back to 44.1/16)
- This seems like the best chain, but the most resource intensive (ie space, CPU power, etc.)
- gives the best plug-in quality
- sounds best while mixing (if your ears can tell ...)
It would appear that 1 is OK but not optimal, 2, offers no benefit over 1, 3 is better to benefit from the better resolution, and if you do 3, might as well do 4 since it's the same resource requirements.
I believe 3 & 4 would sound better than 1 and 2 since you preserve the plugin resultion. Remember that these act on the individual tracks, and are then mixed down. The final mix is then down sampled. That's the differnce it seems to me ... if you processed each track individually, then downsampled and mixed, I could see how the result would be identical to 1 (and 2). The biggest issue for me right now is resources (CPU bogs after 25 tracks or so) so I'll be sticking with 1 for now
