John Monforte wrote on Wed, 17 January 2007 12:30 |
I am not sure what you mean by "balanced P&G Faders". They did make stereo ones which can thoretically be used that way.
These are model #1550, which, in the incarnation that I possess, is a Ward Beck-destined balanced mono fader with 600 Ohms total Z.
They have a stereo balanced fader, model 1552, also. My understanding, which may be mistaken, is that if I were to use one of these faders to attenuate both left and right channels, in single-ended configuration, rather than the + and - leads of one channel only, the impedance would drop to 300 Ohm/channel and that would not work with the capability of the D/A, which can drive 600 Ohms/channel, at a minimum (says designer).
A knowledgeable man also said:
"The amplifier's input should be AC coupled to avoid any noise-generating DC on
the fader."
John Monforte also wrote on Wed, 17 January 2007 12:30 |
You might find that the faders will be the problem. The tracking of P&Gs can be pretty good, but even still, once optimized at one position, the degree of balancing will deteriorate at others. This is why nobody works this way. Common practice is to unbalance external signals, perform your processing, then re-balance afterwards. Sounds complicated, but it isn't and works quite well, in fact.
Thanks for the heads up. If it works at all, I'm not planning on riding through a given song at any lower than the -3 position. Also, I'd be using a DK Audio vector-scope, which I have to use, already, since some of my balancing is with continuously variable pots. Whereas, I was planning on simplifying most of that fuss by setting and forgetting the pots on the EQ and comp that offer fine-tuning (not stepped), and driving them, as needed, with the post-DAC slidewires (deliberately not linked). During an album transfer, besides the tedium of moving several pairs of cont. var. pots an exactly equal amount of L-R rotation per unit to address level differences from song to song, many a mix is off center and wants one-sided correction, which can only be achieved through the "subtle, but deliberate deviation from unity tracking".
Best Regards,
Andrew
