R/E/P > j.hall
beat detective
<< < (2/3) > >>
Ryan G:
Hence the quotes around developing. It would be a pretty powerful tool if you could select different programs besides Digi's.  I use Pitch N Time, it rocks.  Even if I could just select it to change the tempo of a loop or something, I would have a use for EA and could save time.  One of the few functions that I feel Logic does better.  Gasp.
j.hall:
in chicago right now, wishing i had an ice pick to stick in my eye.
tried elastic audio.  that's a joke too.  considering keeping a version 7.4 rig around.
iCombs:
I'm in the middle of a pretty heavy drum edit project right now using PTLE 8.
I had to jury-rig a BD workflow (no CPT, therefore no multitrack BD), but it's been pretty seamless for me.
Basically, it goes like this:
1) create stereo "Drumslicer" track, set input to available stereo bus.
2) send desired trigger elements (kick in, snare top, toms, perhaps high hat and ride if they're broken out and you think they're necessary) to "Drumslicer" track.
3) Record desired section.
4) Use BD to analyze and split secionts
5) Turn off tab to transient
6) Group "Drumslicer" to the rest of your drum tracks
7) Use tab and B (if in keyboard focus) to split other drum tracks on splits created by BD on the drumslicer.
8) Use Command+0 to quantize...or move them manually.  Unfortunately, I haven't found a workaround for grid strength, but I find that if I'm going so far as to do this sort of editing, smacking the shit straight to the grid isn't going to...ruin anything.  There was probably nothing to "ruin" in the first place.
9) Use BD to smooth edits
10) duplicate tracks (just in case)
11) command+comma to ditch sync points
12) batch fade
13) Consolidate
Going through this process, I've been going from raw drums to completely finished edits in an hour or so.  I'm also using this time to replace bad hits (if I have to)(which...again...if I'm going this far...I'm probably gonna have to) and fly sections around.  Once everything is flown, I run Massey DRT on the tracks and use that to insert my samples.
http://www.youtube.com/embed/YryTJdwKDkA
A quick vid on how I do that.  I'm down to about 2 hours total time from raw tracks to completely finished drums (when I have to employ this much...erm...technology).
Ryan G:
I mean this is the most sincere was possible...That seems like way to much work for me.  You can purchase just a license for MTBD through certain people online.  I found one two years ago for $99.  I didn't need the whole MPTK, but needed that.  You could probably find it dirt cheap today and save yourself some time and sanity; but if you like it stick with it.  Just a thought that may be worth looking into.
iCombs:
Well...I don't think I CAN purchase a legit version of that toolkit anymore for LE8.  I'm stuck on LE 8.0.0 because my main tracking system is still a G5...I had it laying around.
It won't be an issue any further when I upgrade to PT9...as far as I'm aware.
And truth be told...it LOOKS like a more convoluted process than it is.  It doesn't really add a whole ton more TIME onto the process vs. MTBD.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
