Author Topic: Acustica Audio releases Nebula2 Free VST-Version  (Read 16404 times)
acusticaudio.com
« on: January 04, 2007, 12:47:33 PM »
Nebula2 represents a quantum leap forward in audio processing. Using Volterra Kernel series inspired technology, Acustica Audio has developed a truly unique plugin that is capable of emulating numerous types of audio equipment; ranging from equalisers, filters, microphones, preamps, compressors, and reverbs. However the list of the types of emulable equipment is considerably larger than the aforementioned listing, as Nebula2 is also capable of replicating generic time-variant processors and effects such as flangers, phasers, and choruses.
Features
   * DYNAMIC RANGE: 192.5 dB
   * FREQUENCY RATES: 6Khz, 8Khz, 11.025Khz, 14Khz, 16Khz,  22.05Khz, 24Khz, 32Khz, 48Khz, 60Khz, 64Khz, 70Khz, 77Khz, 88.2Khz, 96Khz, 176.4Khz, 192Khz, 352.8Khz, 384Khz
   * HARMONIC ORDERS: Program-dependent: 0 to 4
   * INTERNAL BIT RATE:
         o AUDIO
           64 bit floating point for optimizations 1, 3, 4
           80 bit floating point for optimizations 2, 5, 6, 7
         o CONTROL SOURCES
   * IN/OUT BIT RATE: 32 bit floating point
Nebula2 Free comes with a number of high quality FREE presets.
http://www.acusticaudio.com/images/products/11free.jpg
www.acusticaudio.com | Nebula2Free | Volterra Kernel series inspired technology VST-Plugin, emulating numerous types of audio equipment.
resolectric
Re: Acustica Audio releases Nebula2 Free VST-Version
« Reply #1 on: January 05, 2007, 09:06:52 AM »
Cool.
I took the liberty to post the info on another Forum, in my country.
You can check it out here.
acusticaudio.com
« Reply #2 on: January 05, 2007, 04:06:14 PM »
hello and thanks for your interest!
cerberus
« Reply #3 on: January 07, 2007, 01:59:59 AM »
i am a mac g5 user. i mix and master professionally with cubase sx3.  this is interesting to me in theory, or at some point when and if i change my computer hardware to intel... but i still plan to stick with osx.  do you  think that osx support is not necessary?
jeff dinces
acusticaudio.com
« Reply #4 on: January 08, 2007, 08:09:32 AM »
Hello,
please join www.acusticaudio.com for discussion.
MAC Version is planned already, but we do not have a date yet.
acusticaudio.com
« Reply #5 on: January 15, 2007, 11:26:28 AM »
Nebula2 free 1.2.720
- bug fix - tail size returned to the host
- bug fix - resume command is supported, in Wavelab 5 if you stop the player tails are cleared.
- bug fix - different IDs for each plug, blocking bug for PT.
- bug fix - multithread support in Sonar.Tested using a Pentium Duo 1.8Ghz, Asio4ALL & Sonar 6 demo (multiprocessor enabled).
acusticaudio.com
« Reply #6 on: January 19, 2007, 04:34:20 AM »
Nebula2 1.2.721
- Multithreading bug for Sonar PE (logical processor switching called only during program loading,
- KERN page changements or PROGRAM RATE setting)
- Kernel tails are cleared on host "suspend" command and not on "resume" command
- Graphic interface cpu load reduced. Further optimizations are planned.
- NODROP mode for Sonar and Fruity in the MAST page (press SAVE after).
http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=702
http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=703
Sonar users and Multiprocessor mode
1 - Enter the MAST page (click on MAST)
2 - Change the NODROP parameter to 1 yes
3 - Press SAVE
Repeat the procedure for "Nebula2 free" and for "Nebula2Reverb free".
Pros:  Multiprocessor mode supported
Cons: The host will not report the CPU load for reverbs any more
http://www.acusticaudio.com/uploads/75/0/nodrop.jpg
acusticaudio.com
« Reply #7 on: February 05, 2007, 12:39:12 PM »
Nebula2 1.2.723
http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=713
bug fix: Diagnostic and SSE2 when not supported
bug fix: bug B001 - SSE2 confict with other MMX plug
bug fix: Open GUI and CPU load
bug fix: weird behaviour when double click on bottom menu
Note:
1) disinstall the old version
2) install this one
3) install Library 0 [now the basic programs are shipped separately]
http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=711
http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=712
leban (giancarlo)
« Reply #8 on: February 06, 2007, 04:03:37 AM »
Nebula3 1.2.735
bug fix - Sonar: autosave
bug fix - Cubase sx, live: parameter automation
bug fix - Parameter automation doesn't intefere with MAST, KERN and DISK pages any more
bug fix - Samplitude: 100% cpu load when the gui is active
 http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=749
Note:
2) install this one
Acustica Audio: resistence is useless!
acusticaudio.com
« Reply #9 on: February 19, 2007, 03:25:57 PM »
Nebula2 free 1.2.800
http://www.acusticaudio.com/admin.php?op=DownloadModify& lid=786
New features: status bar working when nebula loads programs.
New features/bug fix: the host doesn’t freeze any more (at loading time). You are able to stop/re-start your sequencer in the meanwhile.
New bug/fixes: new engine “mutex” routines and variables..
New feature: new engine for the performance indicator.
New feature: skinnable interface
New feature: 64bit wave support (here and in the wdeconvolver/nebulasampler). Tomorrow I’ll post a new gift!
All these new features were tested a lot, but we changed many lines of code: this version could have new bugs, never seen before. Please report bugs/mistakes, I’m leaving the old version in the download page, so you will be able to revert to the old one if necessary.
How to set the AquaSkin
Nebula has the same skin as before:
http://www.acusticaudio.com/uploads/75/0/VER12800_1.jpg
But if you edit the XML descriptor (“Nebula2Reverb free.xml” and “Nebula2 free.xml” in your Vstplugins$ directory):
http://www.acusticaudio.com/uploads/75/0/VER12800_2.jpg
and change the SKINNAME from “SkinN2fClassic” to “SkinN2fAqua” you get this:
http://www.acusticaudio.com/uploads/75/0/VER12800_3.jpg
At the moment Nebula loads only BMP (PNG will supported soon), the transparent colour is magenta (255, 0, 255). Just edit those examples in your SKINS folder (located in your NebulaTempRepository$)
leban (giancarlo)
« Reply #10 on: February 21, 2007, 06:01:37 AM »
Official Nebula2 1.2.800b
This is really really stable and working on
centrino
dual core (duo)
xeon
Pentium IV
celeron
The multiprocessor issue on Sonar is solved completely.
Stability was improved again.
The perfomance indicator works also for Centrinos or for power-management configurations.
The performance% IS how much of a SINGLE cpu is used. So for a common dual core system or xeon 15% means 15% of a single processor -> 7% of the total power.
There is a new gift, a Small Plate. It shows a preset made with our new deconvolver, based on the new 64 bit wav support.
It was sampled using a 32 bit card, but since then everything was calculated using a full 64 bits path, without bottlenecks.
It works only with the new engine. It was limited to .950 sec in the original PCM unit, and they are 22 Mbytes.
If you wish a longer tail just tell me, I'll upload a bigger version (it's only a matter of downloading time)
http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=792
http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=793
http://www.acusticaudio.com/modules.php?name=Downloads&o p=getit&lid=794
acusticaudio.com
« Reply #11 on: April 03, 2007, 05:39:17 AM »
Nebula2 free 1.2.877
Core4+ Support!
- Native support for IPP intel library
- Optional support for FFTW3 (you should download from their site)
- New "chainmode" optimization for fft libraries
http://www.acusticaudio.com/uploads/75/0/CORE4+.bmp
Now you are able to select an Optimization algorithm for FFT.
Page created in 0.137 seconds with 21 queries.
