J.J. Blair wrote on Fri, 15 December 2006 18:50 |
I heard the two side by side two years ago and vastly preferred the Pearlman. I don't know what the current one sounds like.
Is Peluso using an EF14 also?
Also, I know that last I heard Peluso was using cheap Chinese cable and wiring and was trying to get Dave to get on that bandwagon, which Dave refused to do.
I'd also like to point on that everything you described about the sound of the 2247, "clear high end" and "subdued bass" is not at all how I every think of the sound of a U47. But then again, as I already mentioned, how can you have a U47 using a dual backplate capsule?
I assume that older Pearlman had the Cinemag transformer? What did you hear differently that you preferred one over the other JJ, and what sources?
I opened the 2247LEs (actually have two of them here) -- one has EF12K, the other EF12. I asked Peluso why no EF14, he told me they ran out of stock a year and a half ago. When these mics were first released they were promoted as using 14s. His web site used to advertise them with "EF14". Now it simply says "Telefunken steel tube".
Does it make a difference? I posted that question a few days ago, got a couple of replies. According to some, EF12 is well suited for mic circuits. Some others say EF14. Some say they are interchangeable, just requiring different connections. EF12 is easier to come by. Obviously neither are VF14, and that is not part of the discussion. So who knows, and does it really matter in the overall view of designing a new mic, where the whole system has to work together to produce the final sound. My M 149 with the miniature 6111 and OPA132 op amp pretty thoroughly thrashes the 2247LE for most things.
Not sure what/where you "heard", but the Peluso wiring certainly does not appear cheap. Very well routed and terminated, all enclosed in plastic tubing and firmly attached to the rails. The circuit board is neat and clean, components are well placed and not just thrown together. The tube is pretty large for this frame, and a small section of the flange was removed on each side to allow it to fit inside the rails. Transformer is plain. The housing and grill are substantial, well machined, and nicely finished, much better than most PRC structural products I have seen. Power supply feels solid, good switches and good looking. I did not open it.
As a contrast, one of the last few Soundelux mics I received had the entire capsule stalk free and flopping, banging the capsule against the grill. On another the stalk screw was loose and the capsule was spinning around. Both new, out of the box.
Why on earth would J Peluso "try to get Dave on that bandwagon" of supposedly cheap wiring? I know he is selling components to Pearlman, who then builds his own versions of Peluso's mics. Which is the "real" mic maker?...
I can't discuss comparison to U47, since I don't have that mic here. Recordings I have heard of it have varied from this Peluso sound (clear and strong), to dark and muddy, to fantastic vibrant midrange and textured bass. So which 47 are we talking about? But I know what you mean, I would not choose this 2247LE sound as my all time preferred "U47" tone.
I don't know about the capsule he is using, would like to know more. Is it really the "K67" type in the 22 47LE? Interesting, if that is the case. I would agree with you, doesn't make sense, unless he does something like the M 149, where the rear diaphragm can be disabled at one pattern. I don't have any information about anything like that being the case.
One-to-one sample recordings of Peluso v. Pearlman would be great, but so far I haven't seen anyone offering any.
Steve
