Max wrote:
"Correct. Once the signal has been converted, there is nothing you can do to clean up the jitter during the A/D conversion. In the above scenario where you are using a CD transport digitally out to a D/A, inserting Big Ben in the path would reduce the jitter created by the transport before it gets to the D/A, therefore making the D/A converter perform and sound better. Any artifacts due to jitter that have already been recorded during the A/D conversion is of course not being corrected by Big Ben (it's too late once it is recorded). "
Max, you are right. You know this, I know this. But it is not what I mean. Those engineers who have found out that their AD conversion sounds better when a BB is used, since it is not clear from the Apogee homepage how they use the BB, it is for me unclear if they are only cleaning up the path in between their converter or cleaning up the converter itself.
Again, there is often a lot inbetween AD conversion and DA, workstation, EQ, cabling, name it, all places where jitter can added to the process, and if the BB is cleaning that path up, you might think it has cleaned up the AD, and it has not.
I would only believe in one test situation, wordclock out BB to Wordclock in converter, AES converter out directly in DA, and listen.
As long as the BB can be used as inbetween reclocker, it can clean up jitter anywhwere in the chain, not only in the AD converter.
Erik Sikkema
