I am the very guilty owner of 2323. Overall I was OK with mine, but I wasn't able to get it where I wanted...sounds like I'm not alone..whew!
Here goes...
In Wavelab:
Waves LinEQ Low band, just a HP filter @ 32hz. I knew I was going to try and get a little more low end out of it and I wanted to make sure I wasn’t getting any garbage along with it.
Waves Q10. Trying to carve out little pieces of mud without doing too much damage to the body of the tune….
I did small 1-2db narrow Q cuts @ 153, 207, 287, 472hz.
I added a low shelf of 4db starting at 100hz to try and get some low end goodness going, when I did all this, the bass started to sound pretty uneven in the little 3-note decending patter that it does quite a lot, so a very tight notch @76 with Q=33.9(!) seem to help out a bit.
Cranesong HEDD to get out to my usual suspects…
Manley Vari-Mu,
The mix seemed pretty compressed already, so not much going on here, max 2db of GR.
Millennia NSEQ-2,
Only used the top two bands, in tube mode for a change. I cut 2db around 1k, Q=08, trying to get some harshness out of the cymbals.
High shelf @16k, +3.5db..trying to get some high end in this thing, but not wanting to try and get it al from one place.
DBX Quantum,
Just used the M/S EQ:
Mid: +2db low shelf @100hz, again trying to fill out the low end a bit
-1db @223hz, Q=1.5…more mud removal
Side: -2.5 Shelf @100hz, trying to make a little room for the lows in the middle
+2.5db shelf @11.5K….is there any air up there???
Crane Song HEDD A/D:
Triode=4
No pentode
Tape=3.5
Back in Wavelab some master section plugs…
Believe it or not….BBE Sonic Maximizer! It just helped the high end in a way I couldn’t really get any other way…if used sparingly, that is. No low contour, and the process set at 1.5.
Voxengo Elephant2, giving me an added 1-2 db of limiting. 4X oversampling
Waves L2, doing the same. 1-2 db of GR and Type 1 dither.
That’s about it! Overall, this was kinda tough to get working, but hey, it was a good learning experience, that’s for sure. It was hard listening to the other entries and not get my ears skewed towards the muddy side starting normal. Also, as someone else noted, this tune will never sound as loud as many commercial CD’s. The RMS may say it’s as loud, but my ears say differently! But, it’s all good.
On the next one!!
Mike Bruce
