Author Topic: U/I versus E/I form factor in microphone transformers  (Read 12857 times)
soapfoot
  • brad allen williams
« on: July 19, 2011, 09:39:00 am »
I've always been curious about something--
I know the BV8 transformer uses a U/I configuration. What are the advantages/differences of the U/I form factor over the E/I form factor in a microphone transformer?
klaus
Re: U/I versus E/I form factor in microphone transformers
« Reply #1 on: July 19, 2011, 11:03:29 am »
Please explain for our esteemed readers what the abbreviations "U/I? and "E/I" stand for, and what they mean.
Thanks,
Klaus Heyne
German Masterworks«
www.GermanMasterworks.com
Kai
« Reply #2 on: July 19, 2011, 11:37:31 am »
Explanation - the letters represent the shape of the iron parts of the transformer:
An U/I type transformer has two "legs" the sides of the U, that can carry individual coils.
On an E/I transformer there's only one place where coils can be applied, one wound on top of the other, on the middle line of the E.
On both types the I is mounted across the open part of the U or E after the coils are applied, to close the magnetic circuit.
If the primary and secondary coil each are distributed to both sides of the U (this means 4 coils total), externally introduced hum can be cancelled out in the U/I type.
Bit like the Hum-Bucker principle in electric guitar pickups.
This is probably the main reason Neumann uses this configuration in most mic's.
I have several Neumann brochures where they point out the fact that they use "Zweischenkel-▄bertrager" ("two-leg-transformer", hence U/I type) to make the mic's insensitive to stray introduced hum, e.g. from power transformers.
Splitting the coils has another advantage: the HF resonance caused by the capacity between coil windings combined with the coil inductance can be shifted to higher frequencies.
Therefore it's easier to achieve a greater HF bandwidth.
Regards
Kai
soapfoot
« Reply #3 on: July 19, 2011, 12:05:01 pm »
For purposes of illustration:
EI transformer cores
EI transformer, completed
UI transformer cores
UI transformer, completed
soapfoot
« Reply #4 on: July 19, 2011, 12:05:59 pm »
Thanks, Kai, for that explanation, which makes a lot of sense.
klaus
« Reply #5 on: July 19, 2011, 03:44:37 pm »
As an example of a mic using both types of transformers (single-coil and humbucker) whose sounds I am familiar with, I'd like to bring up the early and later M49.
*The early M49 used a CT49/1 which had single primary and secondary coils, and which was originally designed for the initial tube in the mic, a Hiller MSC2, though the same transformer was used for a few more years after the switch to the AC701 tube.
*The next type, a predecessor to the final version, had a single primary but a split secondary
*The final version was the BV 11, with the same chamber and winding configurations (not specs) as the BV8 used in U47: two primaries and two secondaries- a version of the humbucker principle, though in guitar pickups the added reversal of magnet polarity helps with further noise reduction in that application.)
I have switched out transformers in the same M49 mics (which were otherwise left untouched for the test) to hear what the different building types of transformers contribute sonically.
And the difference is audible: The humbucker of the final M49 series is clearly supertior in noise and buzz suppression, and has an extra 4dB output (this is not inherent in humbuckers, but can often be found when the secondaries are connected in series, to get 200Ω output impedance). The BV11's sound is very even and balanced, with very good low-frequency extension.
However, the earlier transformers have a sex appeal of their own, despite the lower output, propensity to pick up (some) external noise sources like generators, neon lights and electric motor noise, and they do have a slight curtailment in the lows. The plus side: they are very fast and translucent, with reedy midrange processing reminiscent of (and complementary to) M7 capsules.
In the end, both types are equal in value to me as a sonic tool of high quality (the transition model is closer to the CT49/1 in sound)
Klaus Heyne
German Masterworks«
soapfoot
« Reply #6 on: July 19, 2011, 04:34:33 pm »
exactly the type of answer I was interested in hearing. Thanks to everyone.
Marik
  • Real Full Name: Mark Fouxman
« Reply #7 on: July 21, 2011, 04:50:43 pm »
Hello Brad,
It is hard to give a 'set in stone' answer as there are way too many variables in each of those approaches, which should be taken into account. That includes core materials, size of the core, winding techniques, ratio, etc., etc. etc.
In general, UI core is more efficient and because of the humbucking winding has better noise rejection (but the EI can also be wound with humbucking topology, or just use Mu metal shielding). They are more expensive because of the extra setup to wind a second bobbin.
Sonically, everything equal, the main difference makes the humbucking winding. Once I made an experiment, disassembled the UI transformer and then reassembled and reconnected it reversing the humbucking topology. It sounded differently--more open and transparent, with less fuzz and "thickness" in the lower mids. That's the difference I usually hear comparing the UI and EI, but again, it is hard to generalize because of many variables.
Many finest transformers ever made were done on EI cores, as well as there were many on UI, so in the end of the day only your ears can tell you what kind of sound you prefer.
Best, M
Mark Fouxman
Samar Audio & Microphone Design
www.samaraudiodesign.com
klaus
« Reply #8 on: July 21, 2011, 05:56:33 pm »
Quote
Can you explain that a bit more clearly: what exactly did you reverse?
Did you reverse the two (primary?) coils relative to each other, i.e. made the output of one the input, and the original input of the other the output, leaving both coils in series? Or did you just reverse in-and output of the series-connected primary (necessitating a reversal of the secondary as well)?
I use the polarity switching of output transformers in mics to tailor the overall timbre, as indeed reversing in- and output of the primary/secondary makes an audible difference, though no hard rules can be applied to determine which set up is better.
Klaus Heyne
German Masterworks«
Marik
« Reply #9 on: July 21, 2011, 06:27:49 pm »
Sorry, I should've been more clear, rather not reversed, but defeated (or eliminated).
In the original humbucking configuration the bobbins were connected as: (-) leads of Pri and Sec of the bobbin 1 to respective (-) leads of Pri and Sec of bobbin 2. Because of such configuration the induced hum is cancelled.
By reversing humbucking arrangement I meant physically flipping bobbin 2 180 degrees (that's why the lamination needs to be disassembled) and then connecting the (-) leads of Pri and Sec of the bobbin 1 to respective (+) leads of Pri and Sec of bobbin 2.
If it still unclear please let me know and I will draw it.
Best, M
Mark Fouxman
panman
« Reply #10 on: July 22, 2011, 09:05:21 am »
Hi Mark, just to be sure, that it really gets clear, would you please draw it!
Esa
Esa Tervala
Marik
« Reply #11 on: July 25, 2011, 10:05:14 am »
Here we go:
Mark Fouxman
soapfoot
« Reply #12 on: July 26, 2011, 01:42:30 am »
Marik,
I know you make some toroidal designs, as well.  How would you characterize those with respect to both EI and UI conventional-core types?
Marik
« Reply #13 on: July 27, 2011, 06:21:21 pm »
Marik,
The toroidal transformers are very different. They are the most efficient of all transformer types, and have the least of losses and distortions. As such they sound quite a bit more transparent and neutral (but by no means sterile). In comparison to EI and UI cores they are more dynamic and many customers describe the sound as fast and musical. Toroidal transformers main disadvantage is higher cost, as the production is quite a bit slower and more complicated.
Best, M
Mark Fouxman
marcus4audio
  • Real Full Name: Marcus philips
« Reply #14 on: June 01, 2013, 12:38:12 pm »
Here we go:
Guys, I read this topic and wonder are the primary coils of the BV08 winded in same direction or opposite? Because if they are winded same way inductance of the primary will be much smaller (4times) if they are connected from one coil end to the other coil end. Correct me if I'm wrong :/
