Author Topic: Drum Riser  (Read 3267 times)
Lord Alvin
Drum Riser
« on: September 28, 2006, 11:41:04 am »
Hi
What advantage is there to building a drum riser?  We have been considering building one to isolate the drums from the floor.  We would hope that there would be less sound transferring to the home downstairs.  Would there be any improvement in the tone of the drums?
Craig Alvin
Upstairs Productions
Oklahoma City, OK
franman
Re: Drum Riser
« Reply #1 on: September 28, 2006, 08:20:51 pm »
There are varying opinions on this topic. I have never been one to believe in drum risers. If you have a very flexible and light weight floor system, then a stiff riser can help the tone of the drums. Some people prefer the tone off the riser as it resonates a little bit.
As far as improving the isolation, the benefit will be minimal. There is some isolation of the impact portion of the structure borne noise, but a modern rock or pop drummer plays so loud that enough LF energy is put into the room (airborne) that is actually excites the walls and floor structurally, so it's pretty much a lossing cause on that front.
fmdesign.com
griffinaudiousa.com
mr jason
Re: Drum Riser
« Reply #2 on: September 30, 2006, 08:25:10 am »
We made a drum isolation platform out of 2 sheets of 4'x8' 12mm MDF with strips of Auralex Foam glued to the bottom to support it. In our old studio this did a fantastic job of isolating the drums from the floor. We had a coal cellar underneath the live room, and so any instrument or drum would vibrate all the other drums, and it just sounded pretty messy in that room. Once the drums were on the platform it really transformed the sound and made the drums sound a lot more focussed. We were expecting maybe a tiny difference at best, but it made a very noticeable difference that we were very pleased with.
Our new liveroom has a concrete floor, but we use the platform anyway. I'm not sure if it makes as much difference to the drum sound in this room..
It could stop some of the thumping sound from your feet stamping on pedals if the platform is resting on 2 inches of foam, but it definately won't stop the problem of sound leaking downstairs.
As Fran points out, once those walla and floor are excited there's not a great deal that you can do if your room and the room below are part of the same structure.
franman
Re: Drum Riser
« Reply #3 on: October 01, 2006, 02:02:05 pm »
... as I said.. some folks are fans of drum risers!
fmdesign.com
griffinaudiousa.com
