Here are the layouts of my control room aprrox. 15'x9'x8' tall I have attached a spectral run of the room at the mix position also ( used a white noise source and a ref mic into my daw ) I'm using Tannoy System 800a's as monitors , the walls are not covered at this point they are 5/8" drywall insulated.
The control room window is double pained doors on thier side ( great way to do a control window BTW ! ) they are flat to the wall also and are on my left side.
My ? is where would be the best place to put the traps ?? I have 3 2'x4' traps that are 4" thick and 1 diffuser ( an arced diffuser ) from Modular acoustics.
I was thinking 1 trap each in the front corner @ 45deg and 1 on the front wall/cieling combo @ 45 , then put the diffuser on the back wall ???
Thanks
Buzz
