compasspnt wrote on Thu, 05 October 2006 23:13 |
Hey Cemal.
Say hi to Scotland. I had hoped to be there starting next week for a couple of weeks, but sadly work here prevents.
Done Terry. Please let us know when you are coming over next.
Quote: |
The motorised potentiometer appears that it could sound really smooth in it's initial gain reduction.
How would you properly control the hold and release so that different types of sounds could be obtained?
The microcontroller compares the incoming signal against the threshold set by the threshold potentiometer. If they are both equal then it applies the release as set by the release potentiometer. If it is still above then it holds until it falls back to threshold level and then applies the release.
Quote: |
For instance, if you wanted things to be very, very transparent and smooth, might not this system be able to recover so nicely that one would never know compression was being applied? Sort of like the perfect human fader-riding robot?
Perfectly possible. Assume that we have a 1mS release time. And the potentiometer will sweep from A to B. We can control and manipulate that speed in various ways within 1mS time frame which may produce interesting audible results.
For example we can apply acceleration and descelleration to the sweep. In which case the potentiometer will gradually reach to its maximum speed and then gradually slow down and stop at the desired point. Or we can accelerate, hold constant and descelerate.
Quote: |
And then say you wanted some real "pumping" compression sounds. Do you think the motors would be capable of simulation of such, and if so, how might that be accomplished?
That would be easy. You would move the potentiometer at its full speed and start/stop it dead. This would definitely produce pumping effect. The amount would depend on the maximum speed that the potentiometer can move.
Quote: |
So, might there be possible Presets that would perfectly emulate various types of known compression, as well as that of "none at all, yet perfect gain control?"
Theoretically this is possible as I explained above but I am not sure of the result we may get. Trying to emulate an electronic process with a mechanical system is an unknown teritory. I have not been there before. It is completely against the way the technology is progressing. May be we should get down and try this thing. We have everything needed here. I will start with modifying an RC servo and see if I can get the response time below 1mS.
Cemal
