Author Topic: Strange goings on in my CR  (Read 8821 times)
dnafe
« on: September 13, 2006, 08:40:37 PM »
Hi All
Been a while
Today I ran the Real Trap test tone CD (10-300hz in 1 hz increments and measured with an RS SPL Meter at the listening position) in my CR room and the numbers came back looking quite good.
The odd thing was there were a couple of groups of frequencies that made the audio appear to be coming from just the right side of the room and some made the audio appear to be on the left side of the room.
Almost like light to heavy panning and then back to center.
I've included a JPG of the layout of the room.
Any explanation and possible solutions would be appreciated
thanks
Don
index.php/fa/3439/0/
Far be it from me to say anything intelligent
dnafe
Re: Strange goings on in my CR
« Reply #1 on: September 14, 2006, 07:38:20 AM »
a bit more info for you
The corner panels are 2 Roxul RX40 3" thick 2'X4' batts stacked floor to ceiling with empty space behind them.
The wall panels are single Roxul RX40 3' thick batts hung 35.5" from floor and ceiling and mounted 3" off the wall
The ceiling clouds are the same as the wall panels but hung 3" from the ceiling
DOn
jimmyjazz
« Reply #2 on: September 14, 2006, 09:33:43 AM »
I'm puzzled, but it looks like the main thing that might throw your room out-of-whack from a symmetry point of view is the bookshelves & keyboard.  Can you pull those from the room, close the door, and see if you're still getting the weirdness?
dnafe
« Reply #3 on: September 14, 2006, 10:01:46 AM »
That was my plan for today...unfortunately they will have to go in the room somewhere
Don
jimmyjazz
« Reply #4 on: September 14, 2006, 10:21:40 AM »
You can't remove them just for the test?  Or are you saying that eventually they have to reside in the control room?
If the latter is true, and removing them eliminates the weirdness you're hearing, could you put them between your monitors and behind your console?  Or at the back of the room somehow?  Maintaining physical symmetry may be critical in your room.  (It's somewhat critical in most rooms, although I don't think I've ever heard of the kind of extreme effects you are talking about.  I think there might be something else at play, too.)
dnafe
« Reply #5 on: September 14, 2006, 10:37:40 AM »
Keeping the room symetric is going to be a bit of a PITA. That being said it isn't impossible...only annoying.
And in answer to your question they can be removed for the test but will eventually have to be put back into the room.
Don
jimmyjazz
« Reply #6 on: September 14, 2006, 10:57:36 AM »
Well, it's almost hard to believe that the cause of what you're hearing is anything but an acoustic issue, but I suppose you might have an amplifier crapping out or something.  If in fact it is caused by the shelves on one side of the room, then finding a way to move them to a symmetrical location will (of course) be worth the effort.
Do you HAVE to have the desk in the back?  That would be a perfect location for bookshelves, if indeed you have them loaded with random books.  It's a poor-man's diffusor.
dnafe
« Reply #7 on: September 14, 2006, 11:19:58 AM »
The amp has been checked out as has the wiring too and from the amp and speakers.
There are four large shelves (60" width) above the desk filled with varying sized and density items from Books to CD's to Tapes to open spots...vary randomly placed
there are also four shelves (3' width)above the 3'w X 2'h X 18"d file cabinet with mostly small nicnack sized items on them.
As for the rest of the room behind the file cabinet it is symmetrical with the exception of the windows behind the acoustic panels.
Amazing what a small piece of furniture can do to skew the room assuming that's the problem
D
dnafe
« Reply #8 on: September 14, 2006, 05:49:37 PM »
I pulled all the non essential gear out of the front 2/3rds of the room and the change is only minor...tomorrow I'll go after the rest of the room and listen again...also could the windows be causing some of this problem?
DOn
jetbase
« Reply #9 on: September 14, 2006, 08:24:07 PM »
the wall on one side looks like an outer wall & the other looks like an inner wall. could different contruction on those walls be causing assymetry of lower frequencies?
sleep is not an option
Glenn Santry
jfrigo
« Reply #10 on: September 14, 2006, 10:43:27 PM »
The solution may be as simple as pulling the file cabinet & bookshelves off the wall a bit. Often the low end in a room is skewed by having a big equipment rack pushed up against a wall. When you pull it a foot or two off the wall, the problem largely (but not necessarily completely) disappears. You may be experiencing a similar problem, though not knowing more about the cabinet and shelves limits the value of prediction. Give it a try. Also, is your front desk open on the bottom? Completely enclosed consoles/desks can cause trouble too.
jfrigo
« Reply #11 on: September 14, 2006, 10:51:26 PM »
dnafe wrote on Thu, 14 September 2006 14:49
Possibly.  I just noticed the windows on that far wall. Those certainly can change how one side of the room responds with bass. Photos could also aid in understanding the space and being able to make suggestions. I assume the construction is standard residential GWB on studs? What are the windows like? How are those panels affixed in relation to the windows that appear to be behind them? Do they cover them entirely?
dnafe
« Reply #12 on: September 15, 2006, 01:45:18 AM »
jfrigo wrote on Thu, 14 September 2006 22:43
I moved the File cabinet out of the room and removed the bookshelves (wall mounted open shelves) off the wall and there's no real difference....now the desk does have a solid front...and I'll look at that this weekend
The panels (2'x4') are presently mounted on stands that hold them centered between the floor and ceiling and approximately 4" from the wall and they do not completely cover the windows...3/4 would be a good estimate with 5" between the back of the panel and the window
The windows are wood - single pane casement windows with an exteior aluminum sliding window/screen
The walls are standard 2x4 with plywood/brick on the exterior walls (top and right end) and drywall on the interior walls (bottom and left end)
Hope this helps
edit - For the record I don't hear this phnomenon at all when mixing or when listening to instruments in solo...only the test tones and especially 120 - 129 hz
DOn
dnafe
« Reply #13 on: September 15, 2006, 01:54:59 AM »
Here's front left...
note these pics were taken back in april when the room was full of junk...it has since been cleaned up but these pictures will give you a basic idea of the room layout as it is today
index.php/fa/3443/0/
dnafe
« Reply #14 on: September 15, 2006, 02:03:04 AM »
Front right
index.php/fa/3444/0/
Page created in 0.065 seconds with 21 queries.
