Author Topic: Materials in Australia  (Read 2457 times)
benjiboo
« on: September 13, 2006, 12:29:58 am »
A quick question to the Australians here, and to anyone else who might know: What is the Australian equivalent of 703-705 fibreglass sheets? And what are good sources for them?
Thanks,
Ben
jetbase
Re: Materials in Australia
« Reply #1 on: September 13, 2006, 12:38:41 am »
i e-mailed this question to insulco the other day. as it turns out they make an equivalent to owens corning 703 under license.
actually, this is from the e-mail:
"Yes we do make the Rigid glasswool product made under licence from Owens Corning.
It is 48kg/m3 and comes in sheets 1200mm x 2400mm in 25, 50 & 75mm thick.
The closest distributor to you is Avant Garde Insulations at  3/61 Norman St, Peakhurst. Ph 9534-5366"
you may want to contact them for distributors close to you.
cheers,
glenn
sleep is not an option
jwhynot: "There's a difference between thinking or acting dogmatically and drawing from experience."
Glenn Santry
http://www.myspace.com/glennsantry
benjiboo
« Reply #2 on: September 13, 2006, 01:54:23 am »
thanks Glenn
franman
« Reply #3 on: September 15, 2006, 04:00:11 pm »
Thanks Glenn...
703 is approx 4lb/CF = 64Kg/M3
705 is approx 6lb/CF = 96Kg/M3
fmdesign.com
griffinaudiousa.com
jetbase
« Reply #4 on: September 19, 2006, 12:41:35 am »
franman wrote on Sat, 16 September 2006 06:00
Thanks Glenn...
Hi Francis,
According to Owens Corning's website, 703 is 3lb/CF (it says 3.0 pcf, which i assume is the same thing - please correct me if i'm wrong), which is equivalent to what Insulco is stating - 48kg/m3.
http://www.owenscorning.com/comminsul/documents/Insulation%2 0Specification%20Technical%20Data%20Guide.pdf
Best regards,
Glenn
Glenn Santry
franman
« Reply #5 on: September 24, 2006, 11:37:02 pm »
you are correct sir...
fmdesign.com
griffinaudiousa.com
