Vladislavs Korehovs wrote on Tue, 19 September 2006 10:42 |
Hi,
Should mixes come unmastered and without bus compression? I can also master my mix.
I think we should stick to mixing. An unprocessed mix gives much better insight in how the mix was made: you can hear how the instruments were balanced, how compression was used in the mix and where the reverb levels are.
If everything is squeezed and limited there's no telling how the mix sounded and this would defy the whole purpose of doing an IMP.
If you want to do mastering you can always go the Brads forum and join the wump.
I have to admit though that I did feel a bit naked sending out a mix without applying a little limiting
