Pages: 1 ... 34 35 [36] 37 38 ... 40   Go Down
Author Topic: Sontecs...  (Read 265817 times)
Gold
Re: Sontecs...
« Reply #525 on: August 11, 2010, 05:46:14 PM »
TotalSonic wrote on Wed, 11 August 2010 16:03
Something is definitely wrong because I'm getting a noise floor of around -80dBFs
I can't take it. This drives me nuts. I'd leave it alone 'over there' but this is totally meaningless. You must use a reference standard that means something like dBu, dBV, dBv, VU(we know the common reference voltage).
Paul Gold
www.saltmastering.com
On the silk road, looking for uranium.
24-96 Mastering
Re: Sontecs...
« Reply #526 on: August 11, 2010, 05:58:49 PM »
For your reference, noise from my 250C:
complete chain in bypass: -97dBfs
only 250C switched in: -93 dBfs
For Paul's peace of mind: ADDA set to -15dBfs = +4dBu
PS: I recall there was a common problem with the 250Cs that gain pots could "turn noisy" over time. This should be so especially around unity position, IIRC.
24-96 Mastering
CD - SACD - DVD
dietrich
Re: Sontecs...
« Reply #527 on: August 11, 2010, 06:33:56 PM »
thanks Robin x2.
Seems correct the +4 change after  being warmed up when put into the signal.
24-96 Mastering
Re: Sontecs...
« Reply #528 on: August 11, 2010, 07:00:12 PM »
hnewman wrote on Wed, 11 August 2010 14:49
Am in the process of having it's organs harvested and transferred to a new boxes with switches, will let you know how it works out.
That's very interesting. Are you doing it yourself or are you having it done?
24-96 Mastering
CD - SACD - DVD
hnewman
Re: Sontecs...
« Reply #529 on: August 11, 2010, 09:07:25 PM »
I think all the 250 series are unbalanced, I figured this out the hard way.   Regardless, I agree with Brad, something is wrong.  My 250ex is quite quiet as long as it's situated properly.
Having someone else switch in the switches, I lost my soldering privileges years ago, after "improving" a mid sixties silverface super reverb.
dietrich
Re: Sontecs...
« Reply #530 on: August 12, 2010, 08:17:02 AM »
Gold wrote on[/quote
I can't take it. This drives me nuts. .
the 250c had 30% more noise than I would like it to. now it has 3% more noise that I like a unit in the chain to have...
that worse?
Matt_G
Re: Sontecs...
« Reply #531 on: August 16, 2010, 08:40:16 AM »
hnewman wrote on Thu, 12 August 2010 11:07
I was surprised to find that my 432C was unbalanced on the input side even though it has XLR in & that it was wired for pin 3 positive! Didn't notice until I hooked up a set of API550M's which also have an unbalanced input, when I had them in series they cancelled each other out... The 432C is balanced out though.
Had mine all re-wired for pin 2+ now & it's all working swell with all my gear now. Though I sold my 550M's for a 5500.. which I personally preferred when I had them side by side.
Matthew Gray Mastering
Brisbane Australia
Ruairi O'Flaherty
Re: Sontecs...
« Reply #532 on: August 16, 2010, 09:35:13 AM »
The 250 schemos I've seen were differential in and unbalanced out.  The GML IIRC has differential in and an impedance balanced output.
Cheers,
Ruairi
TotalSonic
Re: Sontecs...
« Reply #533 on: August 16, 2010, 10:56:45 AM »
Ruairi O'Flaherty wrote on Mon, 16 August 2010 09:35
Yup - that's what's going on with my 250EX as well.
Best regards,
Steve Berson
Phil Demetro
Re: Sontecs...
« Reply #534 on: August 16, 2010, 12:11:11 PM »
Matt_G wrote on Mon, 16 August 2010 08:40
 was surprised to find that my 432C was unbalanced on the input side even though it has XLR in & that it was wired for pin 3 positive!The 432C is balanced out though
Interesting. This is a first I've come across. Had someone been inside the unit doing repairs perhaps??
____________________________________________________
Phil Demetro
Mastering at The Lacquer Channel, Toronto
http://www.lacquerchannel.com/phil-demetro/
David Glasser
Re: Sontecs...
« Reply #535 on: August 16, 2010, 01:43:41 PM »
No, that's the way they were designed and built.
David Glasser
Airshow Mastering
Boulder, CO
dave@airshowmastering.com
www.airshowmastering.com
Laarsø
Re: Sontecs...
« Reply #536 on: August 17, 2010, 01:55:43 AM »
Sontec's MES (Mastering Equalizer w/Switches) has balanced or unbalanced inputs (as ordered) and ordinarily unbalanced outputs.  This is a single-ended design.  If your studio doesn't need balanced signaling, you will be fine without it on the Sontec inputs.
Burgess had the HS-1000 tuned by ear at the Mastering Lab by Massenberg and Sax.   The result - a transistor eq with a tube sound.
Sherwood's tube eq as I understand it also had no transformers.
Burgess has extolled the Manley transformers as being "well shielded."
Firlotte has made a popular op amp replacement for the MES, however, he also like using iron in his "maidens."
Laars
Space Camp Mastering
laarsoglethorpe@gmail.com
"Lack of DSD post filtering fried a lot of expansive twitters." (D. L.)
Laarsø
Re: Sontecs...
« Reply #537 on: August 17, 2010, 01:04:49 PM »
I heard that Sontec's MES has balanced or unbalanced inputs (as ordered) and ordinarily unbalanced outputs.  This is a single-ended design.  If your studio doesn't need balanced signaling, you will be fine without it on the Sontec inputs.
The HS-1000 was tuned by ear at the Mastering Lab by Massenberg and Sax.   The result - a transistor eq with a tube sound.
Firlotte has made a popular op amp replacement for the MES, however, he also I think likes using iron in his "maidens."
Laars
dietrich
Re: Sontecs...
« Reply #538 on: August 17, 2010, 07:49:07 PM »
whats the consensus of hs1000 vs firlotte op?
Wook
Re: Sontecs...
« Reply #539 on: August 17, 2010, 08:49:35 PM »
The Mastering Lab EQ has always been using solid state amp designed by Sherwood Sax from its start. We are using own transformer-less tube electronics but not on the EQ. And our EQ has nothing to do with Sontecs.
Sunny
The Mastering Lab.
Pages: 1 ... 34 35 [36] 37 38 ... 40   Go Up
Page created in 0.093 seconds with 21 queries.
