Viitalahde wrote on Thu, 17 August 2006 16:48 |
One thing, it's often said that the first Watts are the best in Class A amps. How about Class D? I can't imagine the sound to really change much with 10w or 100w output, from the technical POV.
I wonder if you're confusing Class A/B amps with Pure Class A here?
A typical Class A/B amp may have 15-30 watts worth of bias before it strays into Class B operation; unless you master at loud volumes in a large room, you should be in the Class A region most of the time.
A pure Class A amp is an environmental tragedy, and I can't think of any amp that has more than around 30 watts of Pure Class A in the current marketplace (a typical 30 watts Class A amp will likely yield 300+ in Class A/B).
Over the years, OEMs have implemented many systems to try and extend Class A performance, without the efficiency concerns (Class S and "Current Dumping" being examples).
The maximum theoretical efficiency of a Class A output stage is around 19% - with real-world programme material, this is likely to drop to single figures. If you then factor in the PSU efficiency (unlikely to be above 60%), you'll realise that to get 30 watts of Class A, you'll probably have to burn 175-250 watts of power - permanently - per channel...
Even Krell's "Master Reference" (cost around $150USD) isn't "Pure Class A"; it uses Krell's "Plateau Bias" system, which is marketing speak for a sliding bias system that analyses incoming peaks and biases accordingly.
Looking at your efforts with the DIY Sontec, Jaakko, I would suggest you're in a prime position to build a DIY amp to your own 'spec if you want to save expenditure over commercial offerings. The
www.diyaudio.com group *could* be helpful (note the use of asterisks...).
Justin
