Patrik T wrote on Fri, 04 August 2006 10:58 |
Patrik T wrote on Thu, 03 August 2006 21:25 |
Why see red lights glow on the meters and the plugs when people record and mix at 24 bits?
A quote within a quote!
Yes, that's the problem with the digital ceiling. It's psychological (the idea that one can and must hit zero). Plus when you mix, most plugs are hidden from view. This isn't helped by presets with lots of gain, or auto-gain.
Many people don't pay attention to their gain staging.
And when they do, often they'll just pull down the faders.
I think this has always been the case, but in analogue mixer headroom might be more forgiving, or at least the distortion not as ugly.
And then there's the shift in experienced/inexperienced users delivering commercial mixes. I mean, an increase in fader-pullers.
So, I think it will pay off to teach people how to do proper gain staging and to use rms metering like the K-system.
But, to get back on topic, I think what Ged wants to discuss is,
given this situation of having to master dodgy mixes, could a tube-emulation plug-in help and if so, which one works best.
I agree that it's wisest to use the very best EQ you can lay your hands on, but if a mix is on the grainy side, some harmonic sweetening can give very agreeable results, IMHO.
I haven't used the Crane Song plugs (and I think they may not do VST 'cause it's a rotten torrent world out there) but I think in VST, Ged's first suggestion, the Voxengo analog flux suite, is the best you can get at the moment.
