Quote: |
ericjenson wrote on Tue, 25 July 2006 17:09
i don't know what's wrong, but after having 2 failed burns from sequoia in trying to use it this way, and no failures so far after i'd say almost 50 with Gear Pro on my Plextor, i just tend to prefer it; seems more reliable for the purpose.
Wow, I'd look into re-installing it or something - Sequoia's DDP support has been perfect for years...
thank you , this has been helpful, and a big reminder to me: update my drivers regularly.
i emailed magix customer support after a reinstall and a failed burn
they suggested updating the drivers for the plextor;
which i did, over a year out of date, px-712a.
anyhow it works now.
i still haven't got a response from them about their vst/dx support which seems unstable and unpredictable, i haven't been able to track down which plugs are causing the problems, but i get digital clicks in the audio more often then not when using plugins through sequoia. it's not my sound card, which is an Echo Mia, which i also just updated the drivers for; because i can find these clicks in the waveform as sharp spikes where it seems samples were skipped in the processing. so i'm assuming it's coming from the way sequoia is handling the plugins because with wavelab and soundforge , no problems of this kind.
the effects built in with sequoia, like the dehisser, work fine.
