Ok seeing as though everyone seems a bit shy
, I'll kick it off. Let me just say there was quite a number of submissions that were very good indeed so don't feel too bad if I critique yours too much, as I'm being very nit picky.
One thing that should be pointed out, is that the mix was done with high RMS in mind. To this end, the snare was a couple of db louder then was intended so that when it was compressed & limited heavily it would fit into place appropriately without sounding buried. The guitars should be quite a bit taller after compression, brightening & limiting. The low mids & highs are out of balance & need to be corrected to improve the clarity & definition. I had the mix engineer for this track over today & he has since upgraded his monitoring & was cringing at the frequency imbalance particularly in the low mids & highs. We both had a listen through the submissions & agreed on the favourite being mine & "Sunny's". He said if he could pinch some of mine & mix it with Sunny's it would be perfect.
All submissions were level matched & A/B'd against the original mix. Listening was done through Dynaudio BM6A's with a Velodyne DD12 sub with additional listening done through Sennheiser HD600 headphones. Listed here in order from loudest to quietest...
1 NoWo - This one had the highest RMS value, but impressed me the least. Sub frequencies were very hyped around 40Hz, upper lows were ringing like a bell from 70-80Hz. Low mids were scooped losing the definition of the bass & the body of the snare & guitars. The upper mids sounded hollow, thin & brittle. Highs were nice & where they needed to be.
2 THP1 - Overall quite nice, good punch on the kick & snare, I felt like there was some slight phase shifting going on with the stereo image, which made it feel a bit weird, like the centre wasn't locked in. Perhaps a dual mono unlinked compressor or limiter? Guitars, snare & cymbals could've been a bit brighter overall.
3 MattG - In hindsight I could've probably removed maybe 1db at around 238Hz but the rest I am pretty happy with. I've kept the drum transients well considering the RMS level, I worked hard to get the guitars & vocal up front alongside the drums. My main goal was to give it energy & excitement without compromising the quality too much, which I believe was achieved.
4 Hans - good strong level, I felt the 8-9kHz was a bit too up front & the highs sounded 'processed' (not natural). The subs were a bit too hyped & the lower mids were scooped too much, giving it a smiley EQ sound.
5 Mike Bruce - Nice! when the tracks are level matched, yours sounds quite similar to mine in tonality & overall feel. It felt quite open while still having plenty of energy. The depth & width was nice too. Perhaps a little less low mid then what the guys would like, but I don't think this compromises the end result too much. The only other minor criticisms is that the verses seemed a touch too loud compared to the chorus, so the lift wasn't as dramatic as it could've been. The upper mids/highs were a bit too bright/fatiguing for my taste.
6 Luke F - Overall quite nice, loved the tonal balance of the low mids & subs, if anything you could've opened up the very top end more to let it breath. Perhaps it could've benefited from having some more push circa 3kHz to bring the guitars up. The level was nice an open however I felt like the guitars sat back a bit & gave the drums a touch too much focus.
7 Sunny - Great Master! Nice tonal balance, great punch on the kick, good overall energy. What impressed me most was your ability to get the level up while maintaining fidelity & keeping the transients & image in tact. My only criticism & it's subjective... It would've been good to hear it about 1db louder. Apart from the level yours was very close to the sound of mine with 3 small exceptions, mine was a little more dense due to the extra 1.5 db of RMS level & it also had more 3rd order harmonic distortion (not necessarily making it better, just different), probably due to how hard I pushed the Cranesong HEDD & lastly I had a touch more width & depth. This is my fav out of all the submissions I received, if I was hiring for this job, yours would of made the cut. Well done!
8 Ged Leitch - Another tasty master - Ged I liked the low sub treatment, nice density, decent level. I only really have a couple of small criticisms. The top end seems a bit swishy & perhaps a little over pronounced. There is a little bit of a boxy overtone around 238Hz which could do with a small dip. Either way it's a really nice job.
9 Aivoryuk - Decent job, for me the snare & mids in general were a little dull which caused it to lose a little energy. Dynamics were good but it is getting a fair bit quieter then some of the top 10 releases. Stereo width was a little closed in. But overall very close to the money!
10 Eric Jensen - Nice stereo width, I can see where you were going with digging the vocal out of the mix more but the EQ sounded a little harsh around 5kHz & a bit bright & brittle on the rest of the music in general. Having said that the vocal does cut through nicely. I guess this is one of those things where you wish you could have the vocal on a separate stem so that you can EQ it without compromising the rest of the mix.
11 Chris J - Nice Master, perhaps a little conservative level wise (I can't believe I'm saying this to you!
). Dynamics are left in tact while still sounding a little denser. The hats were perhaps a little too prominent & the mids could be stronger to accentuate the guitar & the snap of the snare. Nice control of the lower mids & bass.
12 Cerberus - When level matched against the original tonally it's not too different which is a shame, because the original mix lacks energy & needs brightening up. I am surprised if you've referenced this to Trapt, because your level is a conservative -12.6 RMS average & tonally it's not really in the ballpark. Unfortunately in your effort to achieve higher levels you have lost the punch & impact of the drums. They sound slightly fuzzy, unfocused & pushed back in the mix. The depth, width & openness of the highs seem slightly compromised compared to the original mix as well.
13 TrilliumSound - This one had some good points & some bad points. I liked the separation, width, the overall space & the openness. I also liked the bass guitar tone. The level was quite conservative compared to new releases. Despite the good points, I thought the track sounded over processed & that the upper mids were a touch too bright. The separation distracted from the song at times.
14 ATOR - Something weird is happening with the phase to me, the width, upper mids & highs sound artificially processed & unnatural. The centre channel sounds washed out & undefined. Compressor timing sounds wrong to me. Low RMS level also makes this one too far off the goal.
15 Patrik T - Lowest RMS out of all the submissions makes this too far off the goal. That aside the bottom end seemed to dominate & hog the mix particularly on the kick. Could use more energy in the mids & highs to bring it to life as the snare & cymbals weren't snappy & the vocal was a little buried.
16 Undertow - Something weird going on with the stereo image, the hats feel like they've swapped from the left channel to the right channel & there seems to be some image shifting going on. Drums have lost impact & it sounds a bit blanketed overall, which is surprising given the lower -13.1 average RMS.
17 Pingu - I know you didn't officially submit it but I thought you'd like some feedback anyway... Lowest RMS at -16.3 makes this too far off the goal. The low mids & subs were stripped away too much, leaving the mix feel empty. Highs are nice & the snare is certainly up front (maybe a bit too much?) guitars feel overwhelmed by the level of the drums, this loses too much energy for me.
