back on topic: (btw imo all multiband sucks!
here's what i did:
i put the track in protools no gain.... just a tiny bit of waves lp lowband eq in normal mode (i think it was
-2@379Hz)
then adat out to an rme adi-8 pro on internal clock
from that into a manley vari-mu compressing about 2dB with 4sec. release
massive passive.... some slight boost below 150Hz and some @4.7kHz..... that's it!
and then back into protools with only 1.3dB of limiting in the L2... (ARC off and 3mS release... 0.3dB out ceiling to prevent D/A distortion) no shaping etc.
finally i used peak to convert to 16bit using Pow-r type 1 dithering.... unfortunately i lost quite a bit of my sound in that process.... conversion really hurts.... maybe the next wump should be 24bit
my philosophy was to keep it as simple as possible.... true to the music... and not introduce digital artifacts as i think it turns (primarily) the top end into plastic.... and i also wanted to keep as much of the original dynamics.... we need that today....
