Here are my settings, for the NSEQ-2, I'm going off of memory, so I'll do the best I can.
I started to play with this tune, liked where it was going, and then the Tenor Sax solo came in, too harsh for me. So I opened up the file in Sound Forge 8, used one band of a Waves C4, X-ove points at 1900hz and 3900hz, to tame the solo a bit. I only used the C4 on the solo section, none of the rest of the tune. Then back to my usual set-up...
Source file at 44.1 from Wavelab 6 external gear plug in.
D/A from Crane Song HEDD.
Manley Vari Mu: Med Attack, Med-Slow Release, 3-4db of GR in the shout chorus.
NSEQ-2, -3db, narrow Q around 200hz
-2db, narrow Q around 2k
+1db, shelf at 21K
HEDD A/D Triode=3, no Pentode, Tape=5
Back in WL6, voxengo Elephant2, In=+2 and Out=-.3
UV22 dither and that's it!
I wanted to keep the chain pretty simple, I don't think that a Big Band tune is the place to really go for creativity. There is already a lot going on musically, huge dynamic range, texture/voice changes alrady happening in the tune that keep it interesting so I saw it as my job to not get in the way and just try and let the music shine. Part of letting the music through is not over compressing, IMHO. Big Band is so dynamic, that's what makes the music
swing! As a drummer, playing big band is one of my favorites. You can go from a whisper to a roar in a measure flat! I think that it's essential to try and keep that dynamic life as much as possible. Alright, enough babbling!
I did find the couple of glitches distracting, so a little sample editing in SF8, and it was much better. Also, there was a snare note in the middle of a fill that was pretty clipped around 1:17 that also needed a little help; much better without the extra "digital snap!"
Overall, I really dug the tune and can't wait to dig into the other versions...now if I can make the time!
For now...
Mike Bruce
