First up, thanks for the material, it was a pleasure to work with.
I did two listening sessions. One with all the tracks at unity gain and one with the levels adjusted to correspond to the original. I'm not sure if I have decided which is most valid but in the end I took the notes from the session with the adjusted levels.
As there are so many good versions, and the purpouse of all this is to learn, all my comments are made with extreme levels of criticism engaged. Alot of the comments are nitpicking. Take that into account when reading these comments!
Also keep in mind that I have less than ideal monitoring and accoustics. Things could be interacting with my room...
In no particular order:
ATOR: Too much of the wrong reverb for my taste. (Too small and upfront). It feels like sitting in the back of the room instead of closer up to the band. I always try and sit in the front row.
This also causes lack of detail. Reverb clashes with the ambience/reverb that is allready there making it sound like the instruments are not all in the same room at times.
Pingus: Slightly overcooked limiter on the loud parts. Slightly edgy sound in the louder parts. A touch closed in. Brass sounds a bit strange. Sounds distant.
Schley May: Slightly pinched/nasal sound. A bit harsh on the top end.
OldSonic: Lack of width. A bit lacking in dynamics. The climaxes could stick out more. The sound is a bit unclear.
NoWo: Strange stereo field. Distortion on the brass. Too much compression. Boxed in and nasal sound. Lacking some mid frequencies but too much of others.
Ed Littman: Nice master. I kept Coming back to this one. Open and detailed sound. Favorite version!
MT Groove: Loud but could be a bit wider. Feels very slightly boxed in.
Trillium: Nice master. Could have a bit more low-end or warmth. Clear sound.
Aivoryuk: A bit lacking in high-end. Slightly muddy low-mid. The mid-mid is a touch too forward.
Ged Leitch: A bit lacking in high-end. Slightly too much low-mid. Sound could be more open.
Luke F: Big sound (loud and wide). Slightly lacking in high-end. Slightly muddy low-mid. Could be a bit less
compressed. I don't think this material needs this level of loudness although I am impressed that you can achieve it without completely damaging the sound. Sounds a touch distant when the monitoring level is adjusted to correspond to the level of the original.
Patrik T: Nice Master. Could be slightly more open. Maybe a touch too much low/low-mid.
Pieter S: Nice master. Close to original. Nice Open sound.
Mike Bruce: Nice master. Good balance. Not much to add.
Zetter: Nice master. Very close to original. Could have a tiny bit more body.
Cerberus: Nice master. Could be a touch wider. A bit too limited in the loud parts.
ChrisJ: Very boxed in sound lacking high-end and too much mid. Distorts in the loud parts. Least pleasing version. I don't think material needs this level of limiting. (if it was limiting).
TotalSonic: Image shifted to the left? The drums and bass are not centered any more. Slitghly muddy sound.
Matt G: Nice master. Could be a bit more open/brighter at the top end and maybe a bit punchier.
UnderTow v1: A bit too much limiting. A bit too much low-mid making it sound boxy.
UnderTow v2: A bit too much high-end. Makes it too harsh and looses some warmth because of this. It also brings the cymbals unnaturaly forward. Sound of brass instruments most affected by "new trick".
Alistair
