Hi,
I appreciate this may be the wrong forum but I think you guys will be able to help.
I have a couple of queries:
1. When mixing, where should the master output sit? I’ve been told it should be set at “zero”, between “zero and minus six db”, and that it “doesn’t matter”. Is there a guiding principle, and does this setting have any effect on anything?
2. I have been experimenting with strapping an L2 across the master outputs (set at 0.0db). While there are obvious benefits, there are obvious (transient loss) downsides. Is this practice common? Would it be more conservative to use a compressor across the master?
Thanks in advance,
Yours n00bily,
Michael.
