My entry sounds like crap. I knew better, but I did mine late at night (1am) after a long day AND at low volume (that was the killer)......and it shows....... Excuses I know, but it was then or never.
Analysis:
To my ear, this track is quite thin, highs are harsh and the mids are honky.
Goal:
Smooth the top but still leave some room up there, get rid of the boxiness in the mids, beef up the bottom and (obviously) boost the level - w/o spanking it. I wanted it tight yet still bouncy.
Chain:
Playback
- Samplitude (1st instance)
- Original file (44.1/16)
Process (within Samp1)
- PSP MasterQ (FAT On)
HPF; 23Hz, Knee 0.67
Lo shelf; -0.37dB @ 86Hz, Q=0.50
+0.25dB @ 86Hz, Q=3.54
-1.57 @ 167Hz, Q=1.54
+0.35 @ 217Hz, Q=2.67
-3.57 @ 489Hz, Q=3.26
-0.95 @ 6.57kHz, Q=2.00
-1.05 @ 9.5kHz, Q=1.52
- PSP MasterComp (mode: Soft, RMS)
Ratio=1.4
Thresh=-2.62
Attack=657ms
Rel=262ms
Link=100%
D/A-A/D
ART DI/O loaded with a NOS Telefunken 12AX7; tube saturation at about 95%; not quite +4dB analog gain
Capture
- Samplitude (2nd instance)
Limit (within Samp2)
- PSP Vintage Warmer (mode: Single band)
Drive=+5.30
Knee=2.0
Speed=55.0
Rel=0.28
Mix=100%
Dither
- Samp TPDF; bit depth set at 2.0
Conclusion:
Missed the mark. Bottom is still thin and the kick is not defined well. Top is a little too edgy. Mids not too bad but instead of boxy are now maybe a little canny. Level not too bad, could be slightly louder. Punch & bounce decent. Overall, not thick enough - especially in the upper bass/low mid region.
