Ged Leitch wrote on Mon, 15 May 2006 13:10 |
Well Bob, i'm glad you managed to get the mix downloaded cause this sounds great! Great top end Kick a bit too pronounced overall great stuff!
Thanks Ged,
My main goal was to warm this mix up and try to make the cymbals sound not so "drum machine like". Interesting you should mention the kick. I ran a version of this before the one I posted and went back and added a touch of the kick back in. Althought the mix has some obvious issues, I felt like the more reserved version lost a bit of the original intent.
For anyone interested, here's a quick breakdown on my signal path:
- Playback - ProTools HD|Accel
- Lavry Blue D/A
- Crane Song HEDD 192 - a touch of Pentode and Tape
- Weiss EQ1-LP running in Liner Phase and M/S mode to address the panned cymbals (take out brightness), panned guitars (add mid definition), and vocals seperately (add some mid/lower mids).
- Maselec MEA-2 - took out some annoying kick and added 6dB at 48Hz to bring some extension to the bass guitar.
- Massive Passive - took out some 3.3k in the vox.
- API550m - engaged, no EQ (transformers)
- Chandler LTD-2 -
light compression so I had a touch of dynamics that worked as a whole, + 3dB of gain (the LTD-2 are warmer as you gain up the output stage)
- Lavry Blue A/D - no clip, no saturation engaged
- Weiss DS1-MkII - dessing around 9.4k, Q - a little over an octave wide, 10.0:1, no knee
- System 6000 - multiband dynamics to control the kick issue and some vocal annoyance, touch of de-essing here (some digital clipping occured here as well)
– Waves Trans X Multi - to make the snare transients snap more evenly with where I left the kick
- (if I was going to apply Weiss SRC, it would occur here with a input signal below full scale but the mix came in at 44.1k)
- limiting to -.3dBFS (on pop/rock stuff, my target is usually -9 to -8 RMS)
- pow-r 2
Between the Maselec low end gain and then the low end compression with the 6000, I decided to try to round out/extend the bass guitar and then control most of the kick dynamically. I don't always use multiband but I felt that the kick problem was not an EQ issue as much as a dynamic one.
It ended up being quite a path but it's not uncommon for me to string something like this together if I think the song needs it.
All in all, a fun exercise!
