Jerry Tubb wrote on Sat, 13 May 2006 03:36 |
jackthebear wrote on Fri, 12 May 2006 09:00 | We just moved speakers and worked a bit on the stereo sub placement...
Tell us more JTB... speaks aimed just inside the rooms' rear corners?
Did that extra "octave" on the bottom appear at some point, with placement?
Sometimes an inch will make it happen.
I must admit, I've gotten some vicarious pleasure from looking at your pic.
Like the soothing earth tone colors.
How about a pic from front to back? Ceiling Clouds?
Cheers Tony and Enjoy...
JT
Hey JT,
Glad you like it..needless to say I'm having a bunch o' fun in my own place!!!
The first thing GA did was listen to the room without anything on and walked around for a bit. Then he put his reference disk on (James Taylor)........sorry the title escapes me now but it was mastered by TJ and it wasn't slammed. There was also the usual pink noise test etc...
He immediately felt the upper mids were somewhat lacking which was due to poor speaker placement from my end. He immediately knew what to do. We raised the speakers onto concrete blocks, spiked them and moved them back a little (10 inches) back. This brought the tweeter nicely into line relative to my new listening position. There is about 3.5 metres between my console and the Duns
Instantly the imaging improved and the upper mids presented themselves beautifully. I never heard the Duns sound so good!!!!! The speakers were bi-wired at this point.
Then we revereted to bi-amping the system and GA tweaked the balance. At this stage of preceedings I was in Heaven!!!!
I had the opportunity to check out some of my own reference disks and was blown away by the fact that I was hearing stuff in these rekkids that I thought I knew like the back of my fists.
At this point GA personally felt the subs were not necessary. I asked if we could set them up anyway. So we positioned the subs not too far away from where the speakers were on the outter side of them in small increments. After some discussion we settled on a position that in both our opinions gave the best combination of tightness and extension.
That pretty much was it.
I'm glad you like the pic JT. I will be launching my website on MOnday and there will be a gallery with plenty of kewl shots.
The color scheme worked out great and you're right the room has a very relaxed vibe.
Off to work!!!!!!
