Author Topic: How often do you guys use side-chains on your compressors?  (Read 5551 times)
J.J. Blair
Re: How often do you guys use side-chains on your compressors?
« Reply #15 on: May 21, 2011, 12:07:04 am »
Michael, why sidechain a compressor to the kick, and not just duck with a gate?  Should this be a conversation about ducking?
I don't sidechain compression, usually, but I will sometimes sidechain the release on a gate.  I just did this recently with the room mics on drums, triggered by the snare.
zakco
  • Real Full Name: Zak Cohen
« Reply #16 on: May 22, 2011, 10:29:01 pm »
I do something similar on drum room tracks occasionally. The difference being, that I trigger the room mics' compressor from the kick track when I'd like less of it in that channel. Not very much (2-3db-ish) or very often though.
My API 2500 is usually set to "medium thrust" when on drum bus or the 2mix.
Z
J.J. Blair
« Reply #17 on: May 22, 2011, 11:58:38 pm »
But that's ducking.  Is the compressor also compressing independently, as well as the sidechain?  I'm not familiar with the 2500's features.
zakco
« Reply #18 on: May 23, 2011, 12:29:10 am »
Sorry...2 unrelated points in my post.
The 1st is indeed ducking. I sometimes follow that with a different compressor not SC.
The 2500 "thrust" control is a 3 position (well, 2 and off) HPF for the detector circuit.
