Author Topic: KM84 power/ volume question  (Read 2139 times)
Mark Lemaire
  • Real Full Name: Mark Lemaire
« on: April 26, 2011, 12:21:11 am »
Is there any common issue with KM84s where there might be a volume drop of, say 5 or 6 db that is fixed by unplugging and replugging in the mic? I have seen my 84 working OK but on certain days not putting out full volume. Replugging it in seems to fix it.
One thought: Is there maybe a partial short/ loose connection in the XLR connector that keeps mic from getting full phantom?
Possible clue (or red herring): moving/ shifting the XLR cable during use can cause big discharge noises.
Gentlemen: your thoughts?
klaus
Re: KM84 power/ volume question
« Reply #1 on: April 26, 2011, 01:35:44 am »
In my experience there is no such thing as a partial XLR connection that can repeatedly be dialed in at -5 or 6dB. It's usually either all on or all off.
The steady -6dB gives me another clue: one of the components may be touching ground, and decreasing output due to the inner isolation sleeve between circuit board and housing tube (ground) having been rubbed through.
Do this: next time it's low in output, use a couple of strong knuckle knocks up and down the mic housing, and observe whether the output changes. Also make sure that the -10dB stalk is fully in the low position (no attenuation.)
On the other hand, if this is one of those Klaus-guy modded 84's all bets are off... you may be a victim of that infamous German quality control!
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Mark Lemaire
« Reply #2 on: April 26, 2011, 04:35:28 pm »
Klaus-
You have not modded my 84s, though you have my KM86s....
Perhaps I will replace the plastic tubing (or cover it with a sheet of paper?)to rule out any unwanted grounding? Unfortunately, the strong knuckle knocks will likely cause this issue:
Perhaps that helps prove your theory?
klaus
« Reply #3 on: April 26, 2011, 04:43:20 pm »
Please clean and coat the male XLR mic connectors: Acetone on a Q-Tip, in a pinch 100% Isopropyl alcohol will do.
Once cleaned, coat the pins with Caig's DeOxit 5 or Pro-Gold.
Klaus Heyne
German Masterworks®
