Will Russell wrote on Fri, 31 March 2006 15:41 |
Well, I did it. I mastered someone's CD today and made it so loud that I can't stand to listen to it. I was paid to take perfectly good mixes and ruin them.
Will:
I certainly understand your angst over this but let's not forget in all this that there are ways to make tracks louder without totally compromising the dynamics. And my comments are meant to be general b/c I don't know what gear you have available to you.
Myself, I cannot seem to find a way to do this well with an all digital setup and my digital tools consist of great gear such as 2 Weiss units, TC 6000, K-unit, etc., but I am able to get some competitively loud masters, with decent dynamics, by using some good tube gear in combination with the outboard digital units.
The trick here is to get your signal gain staged up through some analog gear, sometimes using the functions, ie, compressing/eq, sometimes not, or sometimes just a bit, and hitting the ADC with the signal almost as loud as the final master. I use an analog peak limiter before the ADC and a digital limiter afterward, but just a bit.
If you've been following the Ted Jenson post on Gearslutz, another technique is to clip the ADC. And as is continually pointed out on all the mastering webboards, the quality of the mix can make the job easy or really, really hard and sometimes, just impossible.
I absolutely cannot get the same results with my digital chain, but perhaps that's just my engineering shortcomings.
So, IMO, if one is running a mostly plug-in mastering set up, one is not going to have the flexibility to match the engineers that have a full pallet of gear to chose from. Maybe some of the time you can do a great job, but not consistently with a lot of different material.
Perhaps one day the computer power and modeling will be good enough to replace all our great outboard gear but until that day arrives, there is a reason why top of the line mastering houses have suspiciously similar gear lists, not to mention very experienced ME's!
Because of the work I do and people I work with, I have had the opportunity to hear mixes/masters, before and after, of a number of ME's including a few really good ones, such as Ted Jensen and Doug Sax, and you would be surprised how much louder they made the masters and with very little significant change of dynamics.
While I share Bob Katz's sentiment re the volume escalation to some degree, I'm in agreement with Brad Blackwood, Dave Collins, etc., in that we really have to give the customer what they want. We can offer options but proselytizing to clients will limit your work opportunities!
In the case of the Ted master, there was absolutely no instruction from the producer or the record company (a Major) to make the masters loud yet Ted's was significantly louder than the average modern master. I know because my friend/client gave me a copy in case I wanted to try mastering it before he sent me Ted's final version. In the case of the Doug album master, which was a combination of pop and retro swing music , he was told that it didn't have to be a loud master but it came back quite loud!
And here's another good one. Ted was told that his mix was going to be a radio single and that the rest of the album wasn't mixed yet. So, since we have read and visually seen what the Orban radio compressors do to hypercompressed masters, and given that Ted probably has probably mastered as many radio hits as anyone, why would he go out of his way to make this radio master so loud? Is concern for loud masters on radio an urban or Orban myth?
Every master of mine that I have heard on the radio has sounded good so I have no explanations. The only thing I would say is that I have noticed that some radio stations uniformly sound more compressed and distorted than others (in which case everyone's masters sound degraded) but some seem to know how to handle modern masters well enough.
There is an AM sports station in Toronto that is playing a couple of jingles that I mastered and I am very pleased with the way they sound. I didn't try to make it the loudest one on the block but I set the output level so that is would fit in with other music that I have heard on that station. Would you believe that the station requested mp3 files! I made the highest possible quality mp3 files and it still sounds good but I guess we have to keep in mind that it's AM radio. Anyone else have comments or observations that would explain any of this???
Andy,
Silverbirch Productions.
