Author Topic: A digital question  (Read 7062 times)
Ashermusic
Re: A digital question
« Reply #15 on: March 12, 2006, 11:04:06 AM »
DamnYankee wrote on Sun, 12 March 2006 13:27
garretg wrote on Sun, 12 March 2006 04:06
So I guess my point is that you can't say that DVD looks bad just because it's digital.   It looks bad because it's digital and it's horribly overcompressed.
Digital will never be able duplicate analog due to its bit/byte limitation - it defies the law of physics.  Digital will never be able to dedicate enough bits/bytes to exactly duplicate the saturation, tint/shade of hue of a color that your eye sees in the real world.  Digital can only approximate because of bit/byte limitation.  Digital pictures appear "sharper" because the bit/byte limitations can't duplicate the detail of natural smoothness...and it never will.
In the case of your CD 128kpbs sound quality, that's the bare minimum of bit/bytes that gets the digital format to sound acceptable.  But even if you increased the bit/byte level by 1,000x, it still will not accurately reflect what your ear truly hears on magnetic tape - or in real life.
One more thing: Digital creates odd-order distortion and phase angle destruction - and our brains are programmed for even-order distortion: Analog.
Now, magnetic tape doesn't reproduce sound exactly as we heard it the first time either, but it's light years ahead of where digital is.  Digital is a huge step backwards in sound and video reproduction, but as Tom Scholz says, digital is cheap, it's easily manipulable, and it adds to corporate bottom line.
from drewdaniels.com
"SOME TECHNICAL BACKGROUND ON THE DIGITAL VS. ANALOG DEBATE
There in fact is more ?information? in a high quality 30 inch per second analog tape recording than in a typical modern CD-quality digital recording, there is also more useless information?the stuff we know as noise?quite a can of worms whenever arguing the merits of analog versus digital.
Humans hear with their ears ? which are, strictly speaking, digital in nature,2 ?and with the brain, and to some degree depending on volume level and frequency, the whole body.  Psychoacousticians call the human hearing system the ?ear-brain,? and this description must be kept in mind whenever thinking about or offering argument about recorded audio.  At very low frequencies, sound is increasingly felt with the skin and skeleton.  At very high frequencies, hearing is increasingly ?sensed? with the tiny hairs called cilia on the face and ears, which are visible in bright back light.
Some of the extra information contained in analog tape recordings or analog direct to disc recordings, specifically, frequencies above the range of typical human hearing and loudspeaker reproduction capabilities, may be useful to the ear brain in the process of hearing music, but  extra information that is not part of the original musical sound sources may in fact not be at all useful?it may be only noise, tape hiss, tape over-modulation, record groove or tape modulation distortion or tape surface scrape, or a host of other non-linearities that really have nothing to do with the recorded music.  Extreme low frequencies, below the range of musical instruments but still within the range of human hearing, are almost completely lost in analog tape recording due to the fact that the signal wave lengths are so much longer than the physical width of the tape head itself.  This latter limitation is absent in digital recording, which captures frequencies as low as the analog input circuits allow?usually somewhere in the range of one to two hertz.
When digital CDs were introduced in 1984, there was much talk about how the ?warmth? of analog recordings seemed lost.  That same observation is no longer significant today.  The reason is simple; we have grown accustomed to the sound of the audio which we have at hand?that which we hear every day.  Before 1984, when we knew only the hiss of the tape and the crackle of the LP, it was disconcerting to hear clean, pure audio.  We simply were not used to it.
Classical music recording engineers of course, were immediately enamored of the clean sound, having heard lots of clean audio through headphones from live microphones, which were never processed or fed through blinking boxes that squeezed, squashed and manipulated the original signals.  However, human males have enormous difficulty integrating the experience and knowledge of others?particularly competitors?with their own knowledge, and so the experience and observations of classical music recording engineers was lost on the majority of non classical recording engineers.
In actual fact, virtually all of the high end stereophiles (and by that I'm talking about the super tweaks who spend as much as a quarter of a million dollars on a stereo system), who had spent a significant amount of time at concerts listening to live acoustic music, immediately embraced digital recording and then the CD.  Only listeners whose primary exposure to music was LP recordings and cassettes were ever among the group who found fault with the sound of CDs.
When the first CD re-releases of some popular LPs first appeared, there was a brief time lag before mastering labs figured out that the extensive EQ and processing exceptions made to compensate for the mechanical transfer functions of vinyl records and phono cartridges was not needed for CD mastering, but that abated as quickly as a year after the introduction of the CD to the mass market and has not been an issue since then."
Says it for me.
Composer, Logic Pro Certified Trainer, Level 2
Author of "Going Pro with Logic Pro 8"
www.jayasher.com
Steve Brady
« Reply #16 on: March 12, 2006, 11:05:30 AM »
wwittman wrote on Sat, 11 March 2006 23:19
It's the same reason why in an analogue recording you hear the depth and air around things and in a digital one, it seems flatter and shallower.
Steve Brady
Steve Brady
« Reply #17 on: March 12, 2006, 11:44:49 AM »
*snip*
"Humans hear with their ears ? which are, strictly speaking, digital in nature..."
No disrepect here, but this premise is incorrect.  Hearing is based on analog's mechanical and electrical energy - it's no way shape or form, "digital" in nature.
Those tiny hairs are actually nerve cells that perform probably one of the most critical roles in hearing.  They differ in length and also have different degrees of resiliency to the cochlear fluid which passes over them.  As a soundwave its the eardrum forcing mechanical compression, that compression moves to the hammer of the middle ear and thru oval window of the inner ear (via the cochlea and its fluid).  When this occurs, these hair-like nerve cells are set in motion with each having a natural sensitivity to a particular frequency of soundwave vibration.  The nerve cells send the signal to the brain which interprets the quality, type, frequency, spacial characteristics, time (among a multitude of other things) as "sound".  It's all mechanical and electrical energy - there's nothing digital about it.  That's a biological fact.
*snip*
"...When digital CDs were introduced in 1984, there was much talk about how the ?warmth? of analog recordings seemed lost.  That same observation is no longer significant today.  The reason is simple; we have grown accustomed to the sound of the audio which we have at hand?that which we hear every day.  Before 1984, when we knew only the hiss of the tape and the crackle of the LP, it was disconcerting to hear clean, pure audio.  We simply were not used to it."
The "warmth" is the entire nuance of a particular sound cannot be captured with digital because of the bit/byte limitation which clips the actual sound being heard.  That's it in a nutshell.
*snip*
"In actual fact, virtually all of the high end stereophiles (and by that I'm talking about the super tweaks who spend as much as a quarter of a million dollars on a stereo system), who had spent a significant amount of time at concerts listening to live acoustic music, immediately embraced digital recording and then the CD.  Only listeners whose primary exposure to music was LP recordings and cassettes were ever among the group who found fault with the sound of CDs..."
I think that's a stretch...and folks can say all they want about Digital vs. Analog - it's a free country, but the scientific reality is, the real world is an analog world.  What you see and hear in real life is analog.  The world is built in even order harmonic distortion.  The digital world is built in odd order harmonic distortion.
The scientific and mathematical fact is, a supercomputer cannot dedicate enough bits and bytes accurately duplicate the analog world.  The analog world is built on Infinity.  The digital world is built on finite 0's and 1's.
Most respectfully,
DY
Steve Brady
John Ivan
« Reply #18 on: March 12, 2006, 05:23:40 PM »
Harvey!! I want one of those damn things. Very Happy
All I can say is, the Chicago files jumped out at me really fast. The one that was tape? I heard the space on the second pass. The space around the drumkit knocked me right over.
I work in digital a lot but am planning, with great detail, an analog rig.That's how I started and I hear a difference that is HUGE. I wont claim to understand with any detail, the science behind what I'm hearing but it is without a doubt, there.The word resolution springs to mind every time I listen to my 440-B machine. and that is not as good as analog gets by a long shot,but it ain't bad either.
For me? 2"-16 and mix to 1/2" and then a pair of great converters to edit stuff if I have to. Sometimes, I have to do {ehemmm,,"Mastering"} for demo work. For real stuff? send out 1/2".
I just hear it and I've decided that if I hear it, I hear it and I'll do better work on analog.
This in no way means that I don't "like" digital recordings. I have a bunch of records done in PT that I think sound great!! That,as always, is thanks to the players and engineers knowing there stuff.
Hey, pick your weapon right?
"Transformation is no easy trick: It's what art promises and usually doesn't deliver." Garrison Keillor
hargerst
« Reply #19 on: March 13, 2006, 12:40:31 PM »
I wish I could offer some profound and insightful explanation here, but I can't.  There IS a difference between analog and digital.  For some types of music, it doesn't seem to make much difference; for other types of music, the difference is pretty obvious - sometimes for the better, sometimes for the worse.
It has often been said that, "the last generation of an older technology is better than the first few generations of a newer technology".  I believe that.  My new digital tv is a big improvement over my old TV, and is spectacular on most sources, including DVD's.
But watching the series "Stargate - SG-1" on the SciFi channel, for example, is a study in frustration; blobs of color in the dark scenes are mildly annoying at best and distracting at worst.  The "compression" scenario makes sense to me.
It seems like the whole entertainment industry (video and audio) is headed down a slippery slope - away from quality, and headed for convenience.  At least, it's true for the people in charge.
While iPod's, mp3's, and digital compression may be the wave of the future, I think there are enough of us still around that care about good quality to make a difference.
Eventually, we'll win.
Harvey "Is that the right note?" Gerst
Indian Trail Recording Studio
John Ivan
« Reply #20 on: March 13, 2006, 05:56:54 PM »
Well said Harvey,,
And FWIW, I don't mean to imply that digital means quantity or,bad quality over high quality either. That, as always, is up to the folks in the room. Digital has allowed a new bread of young people to enter the recording thing and in to many cases, they have to many choices and are sold the idea that "that box" can fix everything. I think your right though. Quality will always win out in the end.
Ivan.................................................
P.S. Man, I really want one of those big ass TV's!! talk about fancy Cool
hargerst
« Reply #21 on: March 13, 2006, 07:28:00 PM »
ivan40 wrote on Mon, 13 March 2006 16:56
Well said Harvey,
I had a 42" (that I paid $75 for a few years ago), but it wasn't wide screen or Hi Def.  We found this one at Best Buy (in their "Close-Outs") and we said, "Ah, What the hell, go for it."  I've really been enjoying it.
Steve Brady
« Reply #22 on: March 13, 2006, 07:35:27 PM »
hargerst wrote on Mon, 13 March 2006 17:40
Agreed.  And there will *always* be a difference between digital and analog that is discernible by the human brain - because of the bits/bytes limitation of digital.  You see an example right there on your TV screen with the dark colors (musically, think of low notes/Hz and the long wavelengths that digitally require huges amounts of 0's & 1's to reproduce).  As memory increases, the dark colors won't be so splotchy, but there'll be the issue reproducing the exact color the eye sees in an analog world.
By the way, Harvey - have you ran across this problem on your Topaz:  Rapid, my new Neumann BCM-104 came in today so I'm eager to fire it up to hear what it sounds like.  I turned on my power supply this afternoon, the power supply light didn't turn on but the board lights up and functions as normal - WITH a nasty 60 cycle hum.  I replugged everything in, same results.  Any guess?  Or, do you have someone you recommend?
Thanks much!
Steve Brady
hargerst
« Reply #23 on: March 13, 2006, 07:45:09 PM »
DamnYankee wrote on Mon, 13 March 2006 18:35
Harvey - have you ran across this problem on your Topaz:  I turned on my power supply, the power supply light doesn't turn on but the board lights up and functions as normal - WITH a nasty 60 cycle hum.  I replugged everything in, same results.  Any guess?  Or, do you have someone you recommend?
Steve Magalnick
Victory Technologies Inc.
1780 N.E. 191st Street
Apt 212
N. Miami, Florida 33179
Phone#: 305-944-2503
Email: mag212@comcast.net
Great guy, and knows everything there is to know about Soundtracs boards.
Bubblepuppy
« Reply #24 on: March 14, 2006, 05:01:05 PM »
Actually the cathode ray tube still offers the best images of true black.
There is a new technology coming called FED, Field emission Display.
It works on the same principles as a regular CRT but they will be about 4 inches in depth and @ one 5th the cost. and no limit on size.
I read a lot of propellar Head stuff and I saw this in WIRED.
There is talk it will revitalize the older TV manufactures of CRT displays.
If I’m not mistaken most broadcast mixing and viewing still relies on things like the Sony Trinitron for program broadcast viewing.
"Trust Your Ears Not The Gear"
Bubblepuppy
« Reply #25 on: March 14, 2006, 05:04:24 PM »
What about the MATRIX man?
Are you saying Trinity and Neo are still alive!!!!
DUDE!
Fibes
« Reply #26 on: March 14, 2006, 05:15:43 PM »
I prefer the visuals of a good book.
The Matrix is just a poor, far too late version of Neuromancer.
Please don't consider that an opinion.
Fibes
"You can like it, or not like it."
The Studio
  http://phobos.apple.com/WebObjects/MZStore.woa/wa/viewArtist ?id=155759887
http://cdbaby.com/cd/superhorse
http://cdbaby.com/cd/superhorse2
Steve Brady
« Reply #27 on: March 14, 2006, 06:47:47 PM »
Bubblepuppy wrote on Tue, 14 March 2006 22:01
That sounds pretty cool!  And of course, I can't help but be partial to any new technology employing an anode and cathode - even if the anode plate is made of phosphor.  Very Happy
Gee, 1/5 the cost of LCD???  Don't tell Harvey or his big 44 incher!!!
Steve Brady
Steve Brady
« Reply #28 on: March 14, 2006, 09:51:41 PM »
hargerst wrote on Tue, 14 March 2006 00:45
Steve Magalnick
Apt 212
Thank you very, very much, Harvey!
I just hope this is an easy fix...
Steve
Steve Brady
hargerst
« Reply #29 on: March 14, 2006, 11:58:29 PM »
DamnYankee wrote on Tue, 14 March 2006 20:51
Steve Magalnick
Apt 212
Steve
Sounds like a filter capacitor went out - should be a pretty cheap fix.
Page created in 0.051 seconds with 19 queries.
