ITT Cannon DL96 connectorsUsed ITT Cannon DL 96 zero insertion force connectors
Contacts still in shells, you will have to de-pin them
DL2-96P plugs w/ actuator handle $19.00 ea.
DL2-96R receptacles $4.50 ea.
Modified EDAC metal hood, part #516-230-590 $5.00 ea.
Fits connectors perfectly. Superior to ITT plastic hoods.
EDAC 38, 56 & 90 position connectorsHundreds of used EDAC connector components
Sockets have been checked for non stripped locking nut & both locating pins intact.
Plugs have been checked for intact and straight locating pins
38 position receptacles w/ locking nut, EDAC part # 516-038-000-402 $2.00 ea.
38 position plugs w/ actuator screw, EDAC part #516-038-000-301 $2.25 ea.
38 position metal hoods, EDAC part #516-230-538 $4.00 ea.
56 position receptacles w/ locking nut, EDAC part # 516-056-000-402 $2.00 ea.
56 position plugs w/ actuator screw, EDAC part #516-056-000-301 $2.25 ea.
56 position metal hoods, EDAC part #516-230-556 $4.50 ea.
90 position plugs w/ actuator screw, EDAC part #516-090-000-301 $4.25 ea.
90 position metal hood, EDAC part #516-230-590 $5.00 ea.
solder contact pins, EDAC part # 516-290-500 bag of 100 $8.00
EDAC rack panels2U rack panels with cable tray for 12 ELCO / EDAC 38 pin receptacles.
Like new condition.
2 available. $35. each
EDAC 56 to 16 1/4" TRS breakout panels & drop boxes1U rack panels with EDAC 56 receptacle breakout to 16 Switchcraft N112B 1/4" TRS jacks.
Signal Transport (David Carroll) model Z Panel 16 POS
Used. Clean condition.
4 pieces available. $50. each
Signal Transport drop box with with EDAC 56 receptacle breakout to 16 Switchcraft N112B 1/4" TRS jacks. Ground lift switch for each TRS. Box dimensions 9" x 6.5" x 4.5" excluding handles.
Used. Clean condition. Built to last.
3 pieces available. $75. each
Signal Transport 16 channel XLR stage boxes with snake16 Neutrik XLR connectors & parallel EDAC 56 position receptacle to 32' Mogami multipair snake, EDAC 56 position plug.
Steel box with 1/8" anodized aluminum panels.
Box dimensions 18" x 6.5" x 4.5" excluding handles
8 pieces available $170 each.
BNC bulkhead female to female connectorsHundreds of used BNC female to female bulkhead panel connectors for sale
Kings 2029-17-9 $2.75 ea.
Bomar 335R744 $3.00 ea.
Kings 99-54 $10.00 ea.
Ordering & shipping informationMinimum order $25.
Orders per item over $100. 10% off
Orders per item over $500. 20% off
Items are in the NYC metro area.
A $10. packing and handling charge will be added to any shipping costs.
Payment by PayPal subject to a fee of 3% + $0.30
Please check out my other listingsFS cable and cable assemblies
http://repforums.prosoundweb.com/index.php/topic,1204.0.htmlFS used Neutrik & Switchcraft XLR & 1/4" TRS connectors
http://repforums.prosoundweb.com/index.php/topic,1202.0.html
