+/- 4hz???
Is your AC(Wall) power at 50hz? 48(or so) would be the "main" and 96(Or thereabouts) would be the "first harmonic" of such "transmitted AC signal", no matter voltage. Are you using a UPS on your computer and everything connected to it(Might help)? In the US it's 60hz, 120hz, 240hz, etc.(Each harmonic MUCH weaker than the main frequency.), that have to be dealt with. As my work is non-critical in this region I have the luxury of being able to just notch/shelf below 75hz(My Mackie mixer and audio software has buttons/settings for this common problem.), which takes care of most of it. If it IS critical it may take some knowledgeable electrical work..? Your friendly, neighborhood electrician may be able to help with this? Particularly one with experience supplying "clean power" to computers. At least one of our local electrical companies deals alot in "professional computer installations". Even your AC power provider may have suggestions - or even come out and do tests - at least to make sure all is as good as they are required to provide? Advice, at least, should be affordable to free. Correcting the "problem", to your satisfaction..? That may cost...
TG
