Hello,
Unless there are problems with burnt out chips,
it doesn't make sense "re-chipping" this type of console.
The board is only as good as it's weakest link.
Have you tried the console yet? What is it you don't like
about the sound? What are you comparing to?
The console was optimized for use with NE5532's.
Having said that, I think you could try OPA604??
(but I'm not 100% sure) try it on 1 channel and see if you
like the sound, it could be an improvement, or a could make
things worse, or it could sound exactly the same as before...
Be aware each chip costs over a 1$. It could add up fast
considering you have 24ch plus master plus bus sends and
monitor section return...
Also consider if you re-chip the whole console, the cost alone
might wind up being probably more than you paid for the console.
The Hill is a good console, years ago I used to have a
Series Three 24x8.
I found it comparable to a Soundcraft 600 that I also worked
with, but the Soundcraft had more bells and whistles,
like monitor, talkback, and better eq function compare to the Series 3.
The high end Pro Hill board was the Concept 8400 model.
That board also contained NE5532's or NE5534's.
My sugestion is to leave well enough alone.
If it ain't broke, don't fix it. Don't worry about it.
Use the console and enjoy it as is.
Mario
