Author Topic: What kind of reverb/delay do you use?  (Read 10675 times)
Werewolf10
« on: January 18, 2006, 01:47:01 PM »
Well the title kinda say's it all.  I have been racking my brain trying to get the right sense of "space" in my recordings and few times I get it right "luck mostly".
I have tried a ton of plug-ins and a few cheapo outboard units.  I have heard from many self proclaimed professionals that "all plug-ins are crap" and some that live by plug-ins.  I have also heard from these same people that the only way to go is either a (great room) or a (lexicon 480).
There must be more to this so here's the burning question, How do you guys do reverb?  and/or delay?
NOTE*****I am not a professional, well not in the sense that I make a living off of recording. I hope this doesn't disqualify me from Steve's forum.
Laugh and the world laughs with you.  Weep, and you weep alone. "oldboy"
wiggins
Re: What kind of reverb/delay do you use?
« Reply #1 on: January 18, 2006, 02:31:08 PM »
hey dude, check this out:
http://www.electrical.com/class.php?page=outboard
Every piece has a description.
scottoliphant
« Reply #2 on: January 18, 2006, 02:31:57 PM »
since anything decent in my price range sounds like crap, i put up a room mic and mix that back in for ambience. the closest thing i've heard that I like in a plugin are the plate reverb UAD emulators, but still can't bring myself to use them.
carlsaff
« Reply #3 on: January 18, 2006, 05:50:37 PM »
scottoliphant wrote on Wed, 18 January 2006 13:31
Convolution reverbs can be very good, as well (Voxengo's Pristine Space being among the best of them).
But you're on the right track with room mic-ing. Even if it's a bad room, it will at least sound real. And there's also the option of playing tracks through a speaker in another (perhaps better sounding) room, and mic-ing that ambience, as well.
jetbase
« Reply #4 on: January 18, 2006, 06:07:49 PM »
hi werewolf10 (if that is your real name),
i'll share some tips i've learnt from experience to make artificial reverbs & fx sound more natural. firstly, the units i have at my disposal in my own studio & what i use them for are:
- TC M2000 (reverb, ambience)
- Ensoniq DP4 (reverb, delay, modulation fx, distortion)
- Yamaha FX900 (delay, modulation fx)
- Alesis Microverb III (reverb, delay)
- SIR reverb plugin (reverb, ambience)
as you can see i use mainly outboard units. this is because i run a mainly analogue studio. to my ears the SIR reverb is the most natural sounding, but when mixing i use only the outboard units due to the nature of my studio. here are the methods i use to make them sound more natural:
1. eq fx returns, roll off highs & lows, & also there is an area around 2k that i notch out which helps get rid of the "digitalness" of the reverb/delay. eq'ing the reverb/delay in this way allows me to use more without it being obvious & so creating more a sense of space rather than sounding like a reverb tacked on.
2. use ambient, or room, mics when recording & add reverb to these in the mix.
3. i use different reverbs/fx for different things (e.g. create a reverb for vox, a separate one for drums, another for guitars, etc) but use a little bit of the other reverbs i've used on each instrument as well. so on guitar i might have a specific reverb, but also a little bit of the drum and/or vocal reverb also. the result is more depth & a more cohesive sound.
4. occasionally i'll send a bit of one fx return into another effect (e.g. a short reverb into a longer one) for more depth. actually, i haven't done this in a long time.
those are my tricks. i have to say that i learnt these only after doing a lot of classical & jazz recordings in big spaces with only natural reverb & ambience (concert halls, churches, etc, even a winery!). once i understood how natural reverb sounded i was in a much better position to make artificial reverb sound more natural. the idea is to think of the space you'd like to put a particular instrument in, then create that space using the resources & knowledge you have... assuming you can't physically record them in that space.
hope this helps.
glenn
sleep is not an option
Glenn Santry
vernier
« Reply #5 on: January 19, 2006, 01:15:40 AM »
It's kinda neat listening to records and comparing cuz digital-verb didn't arrive 'till '76.
Werewolf10
« Reply #6 on: January 20, 2006, 12:01:57 AM »
Thanks for all the kick ass replies.  Enough to keep me busy a while Smile
eightyeightkeys
« Reply #7 on: January 20, 2006, 07:59:40 PM »
Each reverb, plug-in or hardware, has it's uses.
I loved the SPX900 MKII "Stone Room" for rock drums, the MPX1 had a really nice silky plate for vocals, for example. I've never owned a 480L/960 though...so...Even the old LXP1 sounded great on drums.
For quite the long while, plug-in reverbs sounded quite good when you solo'ed them with a track, but, after you placed it in a mix you ending up losing it. Where'd it go ? The remnant was whispy, narrow - dimensionless.
But, that has changed in a major way. So, much so that I've sold off all of my hardware units simply because I wasn't using them anymore.
The TC Powercore is now basically my reverb "rack". Particular favourties are the VSS3 and Megaverb. The UAD Plate 140 is O.K. but a little narrow. I don't know...I just don't use it much.
Another interesting reverb, especially for lush, ambient applications is a new one called the R66. It does something the others I have don't.
I need a smokin' delay. Any ideas ?
The PSP Delay Pack, the PSP84/42 are very interesting but a little cumbersome to work with. Some of the controls are a little unusual and it takes a bit of time to get what you want . (Hey Anton it needs an update-something more "typical" with feedback - easy synch to tempo controls) But, you can get some really bizarre and spectacular delay effects.
Dave T.
D&D Music
Ronny
« Reply #8 on: January 21, 2006, 12:36:51 AM »
Dave @ D&D wrote on Fri, 20 January 2006 19:59
KSP 8 is probably my fave at the moment, but Dave any fx applied to a solo track is going to be much more prominent when the track is solo'd. That's not a product of an analog or digital effect or a manufacturer's brand, but due to the dynamic changes on a a solo'd track versus all of the instruments in the mix, where the other track levels mask the fx tail of the previous solo'd track.
electrical
« Reply #9 on: January 21, 2006, 12:39:11 AM »
I'm not a fan of reverb, except sparingly, in well-chosen moments. I don't like the sound of artificial reverbs, but there are some that are good either for "character" or a reasonable simulation of room sound.
Reasonable simulation of room sound:
Quantec XLS, Klark Teknik DN780, one or two patches in the H3000.
Character reverbs:
Well-maintained plate, AKG BX20 spring, Great British Spring, EMT 250, EMT 251, Klark Teknik DN780.
We also have a Quad-Eight BBD digital reverb that is grainy and muddy as hell, but can be a nice what-the-fuck.
best,
steve albini
Electrical Audio
sa at electrical dot com
www.electrical.com
eightyeightkeys
« Reply #10 on: January 21, 2006, 11:51:40 AM »
Ronny wrote on Sat, 21 January 2006 00:36
Ronny, I'm aware of that. And I agree it's not a digital vs analog thing because even my ol' hardware units were digital.
It's hard to explain, but, certain plug-ins just tended to go away in a mix even after compensating for gain, etc...
And not just  the "body"of the reverb ,but ,dimension/width as well.
Anyway, those issues are a thing of the past.
Funny, my MPX1 has been up for sale for about 8 months. Nobody wants it ? Hmm....
Dave T.
D&D Music
cerberus
« Reply #11 on: January 25, 2006, 11:32:52 PM »
electrical wrote on Sat, 21 January 2006 00:39
Character reverbs:
would you please offer some comments about how you approached "Blue Train" with Page-Plant?  When I hear this track, it is a journey into my own soul... this is a heavy ambience track and yet it sounds more intimate to me than almost anything. I just read now that it was recorded at Abbey Road, so that rules out my adobe theory... and it does not matter what gear specifically to me.. i can't afford any of it, so what I want to know is how you approached this particular song.
...or the producers told you to do that one a certain way? although I think you really must have been an artist when you engineered this track You contend you are not, but unless someone else recorded and mixed "Blue Train" Someone is responsible for this, it is high art...I am "educated" and this track gets to me... it is very intentionally what it is.. technically, it is far a superior recording compared to the genre I think it most fits into: blues.
I find this album to be very uneven, I really don't find the engineering on even other good tracks to stand out.. if anything, the hard panning draws attention to the mixing decisons and to my own speaker placement. But Blue Train is.... way different in terms of the production style.  You seem an artist for this recording. How many records have a bass with shape like this.. so much reverb... and such full yet clear 3D bass shapes... and texture one could almost see.. a perfect relationship to the kick drum and guitar...and no mud?  This engineering is so amazing I could go on and on.
It is not just a specific set of reverbs or mic placements or pan positions. it is beyond this for me.. it works..it blows past my ear and brain and immediately straight to my heart...After all these years, I just noticed the unique sound on the kick drum, it is subliminal almost as if there are two kick drums, one you hear and one you just feel...(what the hell micing or compression scheme is doing that?)  The production seems too complex to just point to reverb, or compression, or say it's just a great song and performance.. because we could say that about so many hit ballads.... that I hate. "Blue Train differs most from a typical modern rock ballads of that era, or this one.. or perhaps any era.  Why is it so rare that music is even attempted that sounds anything like "Blue Train".   Why is it a special recording to me?   I will likely never duplicate it, but I think I could learn from the approach that was taken in recording and mixing this one track... To learn to use my own tools to help an artist better reach into the listener's heart, instead of just trying to always do the "technically correct" thing.
jeff dinces
electrical
« Reply #12 on: January 26, 2006, 01:50:08 AM »
cerberus wrote on Wed, 25 January 2006 23:32
It was recorded live in Studio 2 of Abbey Road. Beautiful, beautiful room. I don't recall there being any reverb added other than the room sound on this one. Maybe a little plate on the vocal. I won't remember without listening, and I don't have a copy at hand. Jimmy did the electric 12-string (including the solo) live, and I don't recall if there is any other guitar on it.
Jimmy, Robert and the band are responsible for everything you hear, and though it's nice to be complimented, I honestly don't think I can take any credit for you liking that song, other than not doing anything stupid.
The whole album was recorded (save a couple of tracks from an API at RAK studio) and mixed on a Neve VR. Not my first choice sonically, but if you don't use any of the "convenience" features, the sound to tape is fine.
The only compressor in the studio other than the desk VCAs (which I won't use except with a gun to my head), was an 1178. One side was on the bass guitar (well, on one mic of the two) in tracking, the other was on the bass drum. Robert's vocal was recorded on a Josephson C700, with a couple of dB gain reduction from a Manley Elop that I brought-in.
I can't disagree there, though I don't think any of it is embarrassing. There were a couple of tracks that stood-out as sounding really nice in the end, and this was one of them. I also liked "Shining in the Light" and "Heart in Your Hand."
I can't tell you. I know the feeling. There are a few recordings that I have always listened-to in awe. "Hospital" by the Modern Lovers, and the whole "Fun House" album by the Stooges, for example. I sometimes feel like I've spent the last 24 years trying to make those records again, in one way or another.
If you scratch a dog's back, you occasionally find a spot where the dog seems overwhelmed by the experience and starts kicking his leg in the air, completely unconsciously, unable to contain himself with how good it feels. Sometimes what you're listening to finds that spot on you, and you can't get enough of it.
best,
steve albini
Electrical Audio
www.electrical.com
cerberus
« Reply #13 on: January 26, 2006, 08:13:33 AM »
Thanks Steve... The way you used a linked stereo compressor to process two mono tracks is amazing to me because I do some ducking stuff with stereo compressors in m/s, but I always throw away the "key" side. But I think the method you just outlined will be a  very important lesson for me... to help me work toward an organic balance in mixing...to follow the "laws of thermodynamics" in my work...to let the water seek it's own level.  I see now in this a way to get two mix elements to "talk to each other" and work out their conflicts directly at once. Thank you for sharing this technique; and for your other candid answers.
jeff dinces
electrical
« Reply #14 on: January 26, 2006, 12:17:28 PM »
cerberus wrote on Thu, 26 January 2006 08:13
Sorry, I didn't explain myself. I was using the 1178 as two mono compressors, not linked.
best,
steve albini
Electrical Audio
www.electrical.com
Page created in 0.074 seconds with 20 queries.
