Ok, we've done it:
on SysEx:'Dump Request', using either of the Yamaha selections, set to ch ID 1
On the Sony:select: System/MIDI/
'Basic' set up set to Ch1 & MIDI function set to Out (not Thru).
'Bulk-Tx' set to U1+U2 (or ALL) and 'Execute' counts through as mentioned and now shows data received on SysEx (about 96kb).
Transmitting back out via 'Transmit File' on SysEx indicates as such via the bars at the bottom of the window.
Having done tried all that, I suspect I've lost my user presets as the Sony wont function when accessing the User banks, which also show nothing, all indicating the battery is
dead.
And now, having removed the lid to replace the battery - I can't remove the existing 3v battery from its housing on the board!
[edit: done with a small flat head screwdriver to lever it out. On power up I got a blank screen and zero functionality, therefore I had to re-initialize to factory settings by holding Save & Enter during power up].
One nice thing to see, however, is the SBM chip. I'm still not sure as to the quoted 52bit internal dsp, not being an integer multiple of 8.
But maybe I've helped save somebody else's data...
Hey, can we share presets?
