ruberbullet wrote on Sun, 25 December 2005 17:01 |
I need to retune some files recorded in 440 to the european standard 442 hz....(the Steinway is tuned to 442) What is the best way to do this ? Pitch shifting is generating artifacts in the audio...I guess resampling is the way to go...but how much...how many cents ? When i try -0.785 cents it gets wrong (I'm using Nuendo). Does anybody know the exact new sample rate ?
The temperature changing by 5 degrees can alter a piano's strings by 2Hz at 440Hz and typically most people hear no difference between 440 and 442Hz. Are you hearing beat freq's in your material?
Pitch shifting only 2Hz over 442Hz should not cause audible artifacts and I certainly wouldn't change a sample rate if I had pitch shifting without altering tempo capabilities.
What is going to happen to the pitch when your song is played by another master clock?
I'm terrible at math but let me see if I can figure this out in an elementary way. The octave between 220 and 440Hz has 1200 cents and the octave between 440 and 880Hz has 1200 cents. There are 440 cycles between 440 and 880Hz, but only 220 cyles between 220 and 440Hz. ITR, one cent covers more Hz the higher you go. A hundred Hz covers a half tone or 1/12 octave. You can figure that at 440, the next half tone at 100 cents will be A# at 466.16Hz. Divide the difference between 440 and 466.16 by 100 cents and you get an average of .2616 cent per Hz, for that half tone above 440. The next half tone below 440 would be Ab at 415.3Hz. that half tone has an average of .247 cent per Hertz. Because your pitch origin and destination is close to half way between these two octaves, you can figure that the two Hz above 440 are close to .255 cent each or -.510 cents. As you can see I'm no math guy, but I come up different than -.785.
In sampling, we would need to know what rate you are running. Assuming 44.1k. 44,100 divided by 442 = 99.77 samples. Try a sample rate of 44000. I'd strongly suggest running a quality pitch shifter that maintains tempo, rather than changing pitch by sample rate, which may alter the length of the song or alter pitch when master clocks are changed. You still need to wind up with 44.1k in this example, otherwise when you play your 44.0k file at 44.1k, your pitch goes back to 442Hz. I'm not real familiar with Nuendo, perhaps it has a way to re-record a lower rate without altering pitch to destination rate, 44.1k in the case of redbook cd.
