electrical wrote on Sat, 19 November 2005 22:33 |
I heard the low-end problem plain as day. I heard it despite all the drunken/boorish chatter in the room, and despite my suspicion that such a problem (if it existed at all) was being overstated by some engineers. I was flabbergasted when we polled the listeners about whether "the problem" was there or not, and there was not unanimity in the affirmative. To me, being as honest as I can about my thinking and perceptions, it was unmistakeable. Granted, I was the only person in the room who listens to tape every day, and also the only person in the room who doesn't listen to digital playback regularly.
I have no doubt that I could identify the Pro-Tools playback in these initial tests 100 percent of the time. I would like to have been able to try that test.
Mr. Albini,
Just to clarify:
1) Out of all the esteemed sets of professional audo ears in that control room, you were the ONLY person who heard "the problem."
2) In spite of that fact, you declined to take the available test which would have proved and documented your ability to discern "the problem" in a scientific fashion.
True? That IS what you posted.
If that's so, doesn't that strike you as a monumental oversight on your part - that you failed to record your perceptions as you now claim they were, in a test which has attracted so much attention in the audio engineering community which you value yourself a part of?
Doesn't it also strike you as disingenuous to now deny the unanimous SCIENTIFICALLY TESTED results arrived at by your peers with an opinion that can only be taken as antectdotal - because you never took the blind test??
And finally, can you understand why your peers in the audio industry may have a dim view on your conduct as such - that is, your casting doubt on the results a scientific test by making antecdotal claims after the fact which cannot be objectively confirmed in any way?
Put another way: As you are an engineer with an avowed propensity for meticulousness and attention to detail, do you not recognize the inherent paradox of your conduct in this matter?
I pose these questions to you with an open mind, and await your response.
