Author Topic: 1/2" 456 at 15ips .....!!!!!  (Read 19728 times)
bushwick
« on: April 03, 2005, 03:48:59 am »
I am mixing a record for some folks, sort of Elliot Smith, sort of Tom Waits, sort of Kurt Weil, and very organic. I talked em into tape for the mix and was able to find a bunch of 456 for sale here in NYC. I must admit that I have been a GP9 guy and sometimes a 499 guy and almost always a 30ips guy. I wanted to try 15 ips and told the label and client why and they asked for a comparison. I thought it was a cool idea so first we printed to PT back through AD8000, then to ATR at 30ips, then to ATR at 15ips. (I should mention that we run 15ips with IEC1 equalization.)
The 30ips sounded smoother, more relaxed, perhaps not as silky as gp9, but had good body and the music was glued up as expected. Compared to PT everyone agreed that it was nicer to listen to and sounded more "finished". Very true.
15ips? All I can say was the split second I heard 15 I was sold. Can't remember the last time I went 15 and then never to 456, but my god it is so good. If you are like me and have been a GP9/499 user give 456 a whirl when its available again and mix one to 15ips - IEC1 makes a good difference - you won't be sorry.
As for the sound, creamy, rich, big, finished, solid, and much easier to get your ears around... Someone in the control room remarked that it sounded like the sound on tape felt much closer to capturing a live performance in energy and continuity. Glad 456 will be available again. The mastering guy is going to be very happy.
Best,
josh
Joshua Kessler
bushwick  studio
brooklyn, ny
www.bushwickstudio.com
wwittman
Re: 1/2" 456 at 15ips .....!!!!!
« Reply #1 on: April 03, 2005, 12:57:49 pm »
Welcome!
I've mixed almost every record I've made for the last 25 years to 456 at 15ips (0 VU = +6 over 250nW/m).
The one thing I'd suggest strongly is to print DIRECTLY to the analogue.. instead of only giving the analogue the already digitally castrated mix.
You can do it by leaving the machine in input and feeding that to the digital.
Or you can do it in two separate passes.
But either way, there's no reason to A-D and D-A the mix before it goes to the analogue.
Then you'll REALLY see what you've been LOSING.... not just what the tape "adds".
William Wittman
Producer/Engineer
vernier
« Reply #2 on: April 03, 2005, 01:40:57 pm »
15ips is king ..(weird how many still don't know).
MCullen
bushwick
« Reply #3 on: April 03, 2005, 03:18:04 pm »
Hi William-
Yes, I only print to tape straight from board mix buss. (For me, Inbox=bad, console=good). And I print to pro-tools through the ATR electronics. I just like what it does. I am a true believer now in this tape/tape speed combo. I am interested in gp9 at 15ips again too. Would like to compare the two.
Gotta run....stems! Sad((
Joshua Kessler
bushwick  studio
brooklyn, ny
Brian Kehew
« Reply #4 on: April 03, 2005, 11:58:53 pm »
Hey ! How about 1/4" - the way one zillion records we love were mixed. Unless are your tracks are bright digi-stuff, you might not need that much low end subsonic. And DO DO DO try mixing to the machine with less bias than recommended, bias is a "recommended" setting that can easily be bettered if you listen. 30 minutes of experimentation to make every mix sound better!
...And Dolby "A" adds a character you probably will like too - as one person put it "It sounds just like a record should". (NOT Dolby SR)
_________________________________________________________
Rediscovering past methods is interesting - seeing how much GREAT knowledge is left behind in the name of convenience and "progress". Not all old is good, but much of it was...
Relax and float downstream...
Brian Kehew
« Reply #5 on: April 04, 2005, 12:00:48 am »
I have to say I also prefer the GP9 (if you can get it) over all old tape. I liked the old Scotch 226/250 the most, and GP9 has the same warmth with more depth and dynamics, to me.
zmix
« Reply #6 on: April 04, 2005, 05:49:54 am »
That's a blast from the past. I used to LOVE tracking Scotch 226 on a Scully 280 1" 8-track, and mix to 456 on 1/4" on an Ampex 350.
bblackwood
« Reply #7 on: April 04, 2005, 06:14:10 am »
I am often reminded that 15 ips sounds very good (1/4" or 1/2") - it just sounds soooo good. IMO, 1/4" 456 @ 15ips just sounds like rock -n-roll..
Brad Blackwood
euphonic masters
vernier
« Reply #8 on: April 04, 2005, 01:22:56 pm »
Yep, 1/4" 456 @ 15ips exclusively here.
MCullen
compasspnt
« Reply #9 on: April 04, 2005, 01:32:51 pm »
I tried your new format suggestion, and discovered that I could get TWICE as much music on the tape!
Thanks.
Andy Jackson
« Reply #10 on: April 04, 2005, 01:47:18 pm »
Me too on the 15 IEC front. The only problem is noise. It's not that it's significantly noisier than 30ips, more that the noise is a high mid 'shush', rather than a top end hiss, and seems more intrusive. An octave lower I guess!
Really depends if noise is an issue, kind of music etc. I've done all analogue albums with both the 24trk and the 1/2" as 15IEC. However the one I'm working on at the moment (analogue 2"!!!) I'm doing at 30 as it's pretty dynamic (jazz in other words).
Overdrive
« Reply #11 on: April 04, 2005, 03:43:47 pm »
I am sure you meant +6dB over 185nW/m.
FYI, +6dB over 250 is actually +9... a level the 456 will have hard time kipping with.
Mixing to analog is great, isn't it? In my machine room are 4 Studer A80 MkII's 1/4"-2".
Overdrive
Brian Kehew
« Reply #12 on: April 04, 2005, 05:06:01 pm »
I find that 30 ips (twice the sampling rate of 15) is great for some music, with fewer "overs". And 15 (half the sampling rate of 30) is great for some music, especially children's music. I tend to bypass the converters on playback though.
vernier
« Reply #13 on: April 04, 2005, 05:49:36 pm »
Best sounding albums in my collection are 1/4 -15ips ..thats what made me change.
zmix
« Reply #14 on: April 04, 2005, 07:53:16 pm »
compasspnt wrote on Mon, 04 April 2005 13:32
Thanks.
Oh, you kids!
