There were several posts on different pin boards regarding the nature of the signal processing in the Neumann M149 tube microphone.
Aside several advantages in mechanical layout and circuit board design, the mic's circuit eliminates the approx. 4 to 5 dB higher S/N ratio found in classic multi pattern designs.
After several repairs of my (now sold) M149 I finally concluded that the 6111 tube needs a better replacement, I updated it to a good old AC701 (after that the mic worked without any problem). In the process of this modification I stumbled on the rather strange observation, that the signal of the backside of the capsule is not present on the input side of the tube.
I concluded that the back half of the capsule is not passing the tube, not a big deal for an hybrid design. In talks to a tech that works at the Sennheiser/Neumann, he confirmed my findings.
I mentioned my findings to Klaus and some other techs about this mic's unusual set up; somehow this minute detail grew up to become an internet life of its own:
On the Neumann Pin Board, Mr. Schneider's response to a related question was :
"Sorry, but this web rumor of:"tube circuitry is only used in the cardioid pattern" is one of the sillier things you find in our world wide rumor web. Both capsule signals, front & rear, pass the tube, always and in ALL pattern settings."
To confirm or disprove Neumann's assertion, I took apart another M149 to try to figure out what is going on. My findings:
The front of the capsule is going via a decoupling cap right to the grid (input) of the 6111 tube; both systems are connected in parallel, reducing the tube noise into half.
The back side of the M149 capsule is going via a decoupling resistor into the gate of a surface mount array of transistors; then it is leaving the upper circuit board via a quick connect and passing the tube's printed circuit board, disappearing into the lower circuit board.
The final test was injecting a signal first to the front part of the capsule (capsule removed with capacitor dummies simulating the capsule) where I detected and traced the signal right to the control grid. Then the same signal was injected to the back part of the capsule, with no signal on the control grid present.
There may be a test/set up error, that might explain the different statement of Mr. Schneider, but also there is no circuit for the M149 available that could explain the missing back signal on the control grid of the tube.
To sum it up, in my findings the back part of the K47 capsule is processed by a transistor buffer and is mixed after the 6111 tube with the front part of the capsule, Mr. Schneider/Neumann insists that the signal of both half is going through the tube, a statement that is not reflected in the tested mic.
There is still the chance that Neumann changed the design, the tested mic was manufactured in 1997.
Best regards,
