News:
Author Topic: New Neumann U87 Capsules: Finally A Turn-Around in Quality?  (Read 16602 times)
Offline klaus
Re: New Neumann U87 Capsules: Finally A Turn-Around in Quality?
« Reply #30 on: July 15, 2017, 11:18:30 am »
For the answer please read my opening post #1, and update, #23.
Klaus Heyne
German Masterworks®
www.GermanMasterworks.com
Offline kamamuri
  • Real Full Name: Sergio García
« Reply #31 on: June 27, 2018, 04:43:15 am »
Thank you for such invaluable info. Is the capsule in the new U67 reissue the K870/K67? (as far as I know, there is no new capsule available as spare on the Sennheiser site).
« Last Edit: June 27, 2018, 06:28:43 am by kamamuri »
Offline klaus
« Reply #32 on: June 27, 2018, 01:29:20 pm »
Yes, it is. And this mic's response, as that of the U87Ai, therefore is largely affected by the individual response of the actual capsule installed.
Klaus Heyne
German Masterworks®
Offline kamamuri
« Reply #33 on: June 28, 2018, 03:26:24 am »
Thank you. Then my hope is the new batches of capsules of a $7K mic should be better in terms of consistency. I really don't know if I should buy a new K870 for my 1961 U67, wait a little more, or try a vintage second hand and cross fingers (even though, at this point, all choices seems a cross-fingers-matter to me!).
Offline klaus
« Reply #34 on: June 28, 2018, 02:00:31 pm »
I sympathize with your predicament, and am afraid the news is not good for you and anyone who hopes that the same capsule installed in the $7k U67 will be better or different than when it's installed in the $3.5k U87Ai.
If my complete tear down and analysis of the U67 reissue (article currently in progress and posted soon) is any indication, the ills that plague the K67/870 capsule have not been cured: high diaphragm tension on still too many of them.
Though there is a way to reduce the tension and, for a balanced response, bring it into a range of past generations, it is laborious and expensive.
« Last Edit: June 29, 2018, 12:50:14 pm by klaus »
Klaus Heyne
German Masterworks®
Offline kamamuri
« Reply #35 on: June 29, 2018, 08:23:45 am »
In any case I'm glad to be here to face the facts (in spite of these disappoint my expectations). Education first. Thank you Mr. Heyne.
« Last Edit: June 29, 2018, 08:26:06 am by kamamuri »
Offline gtoledo3
  • Real Full Name: George Toledo
« Reply #36 on: July 27, 2018, 06:42:05 am »
So, how do you test the diaphragm tension of an assembled capsule, or do you just listen empirically?
It always seems a little circumspect to me to peg difference down to just that. Small differences in the size of holes in the backplate for instance, etc., could seemingly make as much difference in end frequency response.
It also seems like low tension can be a bad thing... one of the first things to make a capsule sound bad, IMO, is low tension that starts to result in a capsule being overly sensitive to plosives.
Offline klaus
« Reply #37 on: July 28, 2018, 12:38:37 am »
I listen.
Quote
I know it's the diaphragm tension, because once I relax an overly tight diaphragm, the capsule behaves and sounds just right. If it were something else, relaxing the diaphragm to levels of tension found in former times would not bring the capsule into compliance.
Quote
Of course. I speculate that too many K870 were too close to that limit, so they were selected out and rejected, which cost the company too much money, which caused the company to increase diaphragm tension, which reduced the amount of rejects, but which made the capsules sound worse.
But what do I know? Could have just been a new tensioning weight they ordered that was off, or something else...
« Last Edit: July 28, 2018, 12:44:46 am by klaus »
Klaus Heyne
German Masterworks®
Offline gtoledo3
« Reply #38 on: July 28, 2018, 01:03:52 am »
Very interesting, thanks for that response!
