Author Topic: PRINT THRU  (Read 19839 times)
QUEEF BAG
PRINT THRU
« on: February 23, 2011, 06:52:54 PM »
ok...
ATR 102 HALF INCH RUNNING AT 15 IPS.
SET UP AT +6
print a mix, play it back and print thru
on the tape.
RMG 900 tape.
this should take months or years to happen.
if at all.
WTF ?
anybody else have this problem?
Michael Brebes
Re: PRINT THRU
« Reply #1 on: February 23, 2011, 07:00:07 PM »
The hotter the signal on tape, the higher the level of print-thru.  It doesn't take months or years to happen.  I remember hearing it on recordings all the time, even in the vinyl days.  It's one of the factors of recording to tape. Always has been and always will.
QUEEF BAG
Re: PRINT THRU
« Reply #2 on: February 23, 2011, 07:12:45 PM »
the tape is not being slammed, VU peaks at 0dB
tape tension is not excessive, bias is spot on.
this is for sure more than the average print thru...
about on par with that one Zep tune.
zmix
Re: PRINT THRU
« Reply #3 on: February 23, 2011, 11:58:00 PM »
Do you hear print through after the first pass on virgin tape or is it possible that the erase head is not functioning properly?
MagnetoSound
Re: PRINT THRU
« Reply #4 on: February 24, 2011, 03:17:23 AM »
Quote:
SET UP AT +6
+6 over what?
Music can make me get right up out of my chair and start dancing or it can get me so pumped up I have to walk around the block.
It can also knock me back and make me sit there and cry like a little baby. This shit is as powerful as any drug!!!
- Larry DeVivo
Greg Reierson
Re: PRINT THRU
« Reply #5 on: February 24, 2011, 10:48:38 AM »
MagnetoSound wrote on Thu, 24 February 2011 02:17
+6 over what?
One would assume 250.
Magnetized heads / guides? Seems very strange. Is the music very quite or sparse? Have you tried other tape?
GR
zmix
Re: PRINT THRU
« Reply #6 on: February 24, 2011, 02:28:43 PM »
Greg Reierson wrote on Thu, 24 February 2011 10:48
+6 over what?
I assumed +6/185...
Greg Reierson
Re: PRINT THRU
« Reply #7 on: February 24, 2011, 02:35:04 PM »
Damn! Memory fade.... Chuck is correct!
GR
radardoug
Re: PRINT THRU
« Reply #8 on: February 24, 2011, 02:45:59 PM »
Can you measure the level of the print through relative to the main audio?
Print 1 kHz at your reference level. Then with no input, record over the 1 kHz tone. Tell us or supply files of the erase level of the 1 kHz tone.
QUEEF BAG
Re: PRINT THRU
« Reply #9 on: February 24, 2011, 07:50:31 PM »
+6 over 185nW/m  or 355 nW/m
250 nanos is +3dB over zero referenced to 185 nW/m
At the time this standard was established 185 nW is all
the level the tape of the day could handle.
so the 0dB reference still in use today is referenced to 185.
when 456 came out the ads said "Now i can record at +6
and tape hiss is no problem." eveyone just knew what the
superstar engineer of the month in the ad meant.
499 and scotch 996? we just said "sweet now we can go +9!"
any ways... rebiasing for a different tape gave a clue.
after setting the high eq for zero i always look at 15k or 16k
just to see how flat thing are further up.
the API console has 10k then 20k on it's oscillator.
so when i looked at 20k (after setting zero at 10k)
it was -15dB down on the left side and -20 on the left!
derr...that ain't right.
ok so i check the head wrap on the record head as i am
recording 20k... still pretty solid, frickin' low
checking the repro head - whoa! there's the top.
we are not getting good contact on the repro head.
(i won't take the time at the moment to explain except to say
you should ues a Q-tip instead of your finger)
so i swapped in a head stack from another ATR, and
the wrap was fine.
(yes repro and record cal again with different heads)
only down a quarter dB or so at 20k about what i would expect at 15 ips
i also swapped master bias cards, thinking this would be the
most likely of a machine induced problem.
still print thru.  damn
the tape is being erased.
it is not an erasure issue.
i am pretty sure it's a machine issue.
yet another machine in the building has no problem with
this issue.  it is being used in session for another day
in the other room, or i would use it now.
if i have a chance, i will try to make a file or two, but that is not
likely today.
no sense in gettin' to concerned, when i originally posted, i
hadn't ruled out the tape at that point.
i was just wonderin' if other people had any similar experience with RMG.
Bill_Urick
Re: PRINT THRU
« Reply #10 on: February 25, 2011, 12:42:02 AM »
I jus' wanna nough,
is there a plugin that does this?
If so I want it.
Good sense is, of all things among men, the most equally distributed; for everyone thinks himself so abundantly provided with it, that those even who are the most difficult to satisfy in everything else, do not usually desire a larger measure of this quality than they already possess.
slothus
Re: PRINT THRU
« Reply #11 on: February 25, 2011, 01:22:41 AM »
Shouldn't it technically be over 180nWb/m these days....?
Err, anyways...
900 fine with a 102 here this week, last week, the week before. Good luck in the hunt.
I want that plug too Bill. Actually, I'll just check that other website to see if I really do want it.
Brent Punshon
radardoug
Re: PRINT THRU
« Reply #12 on: February 25, 2011, 02:13:18 PM »
Queef, which is it??? You must know. The flux level of the alignment tape is written on the box. Precision, my boy!
I had a case years ago where an ATR100 had magnetised roller guides.
This would cause a type of print through, in that it would reprint the bias frequency, and it would beat against itself, producing a variable frequency whistle. Try demagging all the bearing guides, and of course heads, lifters etc.
QUEEF BAG
Re: PRINT THRU
« Reply #13 on: February 25, 2011, 05:13:22 PM »
sorry if i wasn't clear
355 is +6 over 0vu
what i should have said, i guess is
i am set up for +6 operation which is 355nW/m
what i meant was you could call it +6 or 355, same thing
i was typing as if i was talking.
if i was standing next to another tech looking at the machine,
i would just say +6 refering to the levels it was set for.
or i could say 355nW/m.  usually we just refer to the number of dB over 0.
the machine in the other room is set at +12
i have no idea how many nanowebers that is  : )
i"ll be swapping machines soon, so i can chase this a lttle more
radardoug
Re: PRINT THRU
« Reply #14 on: February 26, 2011, 01:45:18 AM »
See this is where I have the problem. What you are interested in is the flux level of your reference tape. Then you can convert your repro gain setting to a level x dB relative to the reference, or to a flux level.
0 VU is meaningless unless you can reference it to a flux level.
So your reference is 185 nWb?
And you are operating at 6dB above the reference?
I would have thought it more likely that your test tape is 250 nWB.
Interestingly when I was doing a lot of tape testing back when 456 was the common tape, the 3% total harmonic point was generally around 14 dB above 185 nWB. I didn't have a wave analyser and could only do THD. So people operating at an operating point of +6 relative to 185 are already crushing transients quite a bit, bearing in mind the true program level is 10 to 14 dB above what the VU meter shows.
Most newbies have terrible trouble understanding the concept of flux level, and messy references by people who should know make it even harder. Then add in the fact that to increase recording level, you wind down the repro level, and I can see the glazed eyes.
Anyway, this will not affect printthrough apart from the fact that printthrough will occur more with significantly elevated levels.
And one other thought, if you Dolby it you will reduce the obviousness of the printthrough.
Page created in 0.103 seconds with 19 queries.
