Curve Dominant wrote on Fri, 04 November 2005 06:10 |
CWHumphrey wrote on Thu, 03 November 2005 22:44 |
electrical wrote on Thu, 03 November 2005 19:47 | I propose that we use 0vu= -15dBfs as the transfer level, as that provides a nominal equivalent in headroom to any good analog system.
Bob O.'s assertion was that this issue may be level dependant. Wouldn't make sense to also test -18dBfs or -20dBfs? And for the sake of accuracy, when Mixerman discovered this, where was his operating level at?
Hmm...My understanding is with PT, input at around -16dBfs = optimal use of the kit's headroom. Not sure if -15dBfs would yield a noticable detriment in comparison.
That is the question, isn't it? It's all about the details. At Larrabee, we installed one of the first SSL 9K J's in LA. After a few years, some engineers complained that they couldn't hit the mix buss as hard as they could the 4k's. Mark Gruber and I concluded that since the console was direct coupled, and therefore more bottom end succesfully traveled the various signal paths, hitting this mix buss super hard (as in pegging the VU's) was a bad idea. Go figure, SSL had optimized the mix buss for 0VU.
Most PT systems I've used have been setup for -18dBfs. It's same old argument we used to have with the dat machines. Do you push up the operating level to use up as many bits as possible? Or do you set them up as a unity gain device?
Isn't this what has go us all into so much trouble with CDs? Look, we can push the level louder than vinyl. We need to push the level louder so we use up more bits...or do we?
This test needs to be attempted at different operating levels. For that matter, I'd like to see this whole thing repeated at J.J.'s, since he offered. Also, we'd have the chance to try the whole thing with his Apogee converters.
If there's an issue, what specifically is the cause?
Cheers,
Carter William Humphrey
