Hi all,
I have in the past, locked My Da-88's to Cake Walk Pro Audio 9 ,using the DTRS machines as the master. I have the Sync card for these machines and I would send Time Code to the software and would send the Word Clock from the DA'88s to my Layla card. This worked fine.
This time around,I'll be using Cubase SX and Samplitude and would like to use the computer as the Master instead of the DA-88's. The reason for this is I will be sitting in front of the computer and would like to be able to use MMC to start and stop the whole mess. I will also be starting projects in the software and "adding" the DA88's for more tracks to land on the console.
I will send the word clock to the DA-88's along with Time code for address.
My question is as follows.. Is there any down side to using the computer as the master? Is there any reason this is the wrong way to do this on it's face? I still need to look at whether the DA-88's auto terminate and if not, I will do this manually?
Any comments would be great.
Thanks much
Ivan.............
