Author Topic: A BNC to RCA Clock Cable (Really) - Two Questions  (Read 4465 times)
john abney
« on: August 10, 2005, 01:40:52 AM »
My first post here.
I have a SUMO Theorem DAC and a Drawmer M-Clock. The M-Clock has BNC clock outs and the SUMO Theorem has an RCA clock in. I had a BNC to BNC cable made with 75 ohm plenum-grade cable and co-axially crimped-on BNCs. I cut one end and soldered an RCA male to it. I tried my best to get the cable's copper shield to cover the RCA's ground in a 360 degree fashion, but even with a Hako iron and Kester 44, it ain't very coax :-)
Everything's working (I think) but before I invest in a store-bought BNC to RCA cable (assuming such a thing exists) is it worth it?
1. Should my almost-coax RCA be OK, or is true coaxial coverage of both ends of a clock cable that critical?
2. Is the SUMO Theorem - which is supposed to have Burr-Brown D/A, a discrete output, but relatively high jitter using its own clock - worth bothering with?
I'm not a clock fanatic, but I have several digital devices, and an external clock seems the only way to get them all to live in peace. My other DACs include RME ADI-8 Pros & AEs, CreamWare Scope, Alesis HD24 (and a couple of brands I won't mention).
some new jabney & mccarthy songs coming soon to thecodes.net
danlavry
Re: A BNC to RCA Clock Cable (Really) - Two Questions
« Reply #1 on: August 10, 2005, 11:23:13 AM »
jabney wrote on Wed, 10 August 2005 06:40
My first post here.
I have a SUMO Theorem DAC and a Drawmer M-Clock. The M-Clock has BNC clock outs and the SUMO Theorem has an RCA clock in. I had a BNC to BNC cable made with 75 ohm plenum-grade cable and co-axially crimped-on BNCs. I cut one end and soldered an RCA male to it. I tried my best to get the cable's copper shield to cover the RCA's ground in a 360 degree fashion, but even with a Hako iron and Kester 44, it ain't very coax Smile
What is a sumo theorm DAC?
Here are some general comments about cable imperfection:
I assume you paid attention to having both the termination impedance  and cable impedance be the same. In your case it is probably 75 Ohms.
Having said that, the issue of imperfection in the soldered region will effect the transmission path (cable and connectors) impedance in that location. So your question boils down to “how much damage to the signal” will take place when a certain length of the path is at the wrong impedance.
Impedance mismatch does cause some signal reflections. But a short length of mismatch is not as severe as a long length. Also, the slower the signal rise time, the less reflections.
So here is the very condensed answer:
1.If you are using Word Clock, do not worry about the reflections at all, because the repetition frequency is so slow that the reflections due to one clock edge will die out before the next cycle.
2. If you are using AES signals (or higher frequency signals in general), the cycle time is much faster and reflections will have more impact, but a “1 inch long violation” is not going to harm you at all. A 1 inch is about 150 ps (pico second) delay, and I bet your signal rise time is a few nano seconds, therefore you are relatively safe.
The makers of BNC connectors and hardware designed their hardware carefully to accommodate GH signal transmission. A GH (giga Hz) signal rise times are in the few hundred pico seconds or faster. You do not need to worry about an 1/2 inch of bare wire for digital audio transmission, or for audio word clock.
(By "bare wire" I do not mean a palce where you lose continuity, What I mean is "exposed wire". You do want the shield (your return path) to conduct...)
Regards
Dan Lavry
www.lavryengineering.com
john abney
« Reply #2 on: August 10, 2005, 08:29:50 PM »
hi Dan Lavry,
Thanks for the response. You ask, "What is a sumo theorm DAC?"
SUMO made amplifiers and such to sell to audiophiles. The Theorem was their Digital to Analog Converter. Stereophile Magazine rated it pretty highly in the 1990s - at least until one of their authors got a jitter measuring device and found that the Theorem had fairly high jitter. It does sound pretty decent, jitter or not.
As far as DIPs, it has two Burr-Brown chips: a DF1700P, and (the only socket-ed chip on board) a PCM67P. The other large chip (besides the DF1700P) is a Yamaha YM36323B. There are two Zettler AZ820-2C-24DEs which I'd describe more as blocks or modules. The other chips include a P8712A+, an I8432, an S BN8510A, and two LM741Cs. There are also a number of three-legged regulators scattered about the board. At what I presume is the output section, are discrete transistors, and what appear to be two 1/2" long red LEDs. I will not pretend to know what the various chips do, though I think I have some idea about the B-Bs and the Zettlers.
As to whether I'm getting clock via the wordclock or the digital in, I honestly can't say. If I recall correctly, every other D to A converter I have requires that the user select the clock source.  Changing from 44.1 to 48k at the digital source will re-clock the Theorem causing an audible click, but I'm not sure if the discrete 'Clock-in' is supposed to automatically over-ride the internal clock or not. I need to experiment but I'll need to drag out some old, cheap loudspeakers to try it on.
Again, thanks for the response. I feel a lot better about my soldering after reading your reply. Even if turns out to be a cable to nowhere, I'd say I managed to reach about 90 or 95% of true co-axiality (if that's a word :-)
best,
John
Page created in 0.095 seconds with 18 queries.
