Dan, that is perhaps my point, I just wasn't clear perhaps. I've measured tons of gear that uses opamps, and even the pedestrian stuff commonly has excellent square wave response (bandlimiting being the obvious "flaws" to various degrees) as well as THD levels well into the noise floor over the audio band at "nominal operating level", and typically 0.01% just below clipping over the audio band. The latter test does shake out the weaker designs at 10 or 20 kHz.
I need to breadboard a 553x and run some tests again. It's been too long since I did that, but my recollection was that THD was extrememly low at any frequency and level (up to near clipping).
Perhaps 2-tone IMD tests with HF tones will reveal something different...haven't tried that. Also, topology (inverting vs non inverting, output load-both R and C, closed loop gain, etc) could result in variable test bench results.
In any case, if bench tests show vanishingly low THD and excellent square wave response, what additional tests can be run to show why chips like 553x's sound so (allegedly) awful? Or, for that matter, even the higher priced Burr Brown, Analog Devices, or Linear Technology chips are allegedly ghastly as well.
Bri
