A question for all the digital gurus out there.
I'm contemplating getting an RME card with optical connections to my AD16X and DA16 to run a Logic setup on a new G5.
I'd like to put the computer 10m away in the machine room if possible.
If I run plastic Toslink cable over that distance from the card to the DA but clock the DA with word clock from the AD16X, would that eliminate any jitter coming down the Toslink cable?
Would the same jitter issue go away on the AD side if I clocked the card from the AD16x using word clock?
Is there any risk of interface jitter or distortional rounding of the squarewaves due to reflections, etc as a result of that plastic cable or does the cable only cause a gain reduction (optical, not audio obviously)?
Thanks very much in advance!
